Does anyone have any experience with half a 6SN7 as a gain stage direct-coupled to the other half as a split load inverter? Specifically, what is the bias point for the inveter? I have -2.5V currently, and I can't get more than 10V peak out of the stage.
The monoblock amp is 6SN7 gain --> 6SN7 inverter --> (2x)6V6GT in class AB push pull. B+ is 250V on the output tubes, and they have -15V on their grids. I can only get 3.7W at the output before it clips, which seems about half what I should be getting. Is this tube just not capaple of swinging two 6V6's with the opterating point I have??? ![]() Help! I spent a good chunck of this weekend troubleshooting and I seem to be at a loss. Joel |
#2 |
"chunck"?
"opterating"? "inveter"? I apologize for all the spelling errors! I'm really not retarded.
#3 |
diyAudio Senior Member
Joel,
With VA at 250VDC vg- can be set at -8 VDC,Ra would then be around 7k7. This should give enough headroom so it will not go into clipping. Just my 2 cents worth. Good luck,
Frank |
#4 |
Depends on the current and load. Here's a circuit using that same configuration: http://www.space74.freeserve.co.uk/diagrams/a7-e.gif
#5 |
Joel,
Check voltages,I suspect some carbons have gone haywire. Just a hunch. See you,
Frank |
#6 |
Are you sure thats not just the point where it reaches class B? Are you using inverse feedback to cancel the crossover distortion?
I have a 6V6 PP amp using 375V on the plates but only a plate dissipation of 9W per tube... Gets into class B real fast, but with a little NFB it sounds awesome, and it has power to burn...
#7 |
Thanks for the input so far guys!
Frank, I checked the voltages - seems like everything is fine. I increased the bias to -17V on the 6V6's, and put a 5V4 rectifier in, increasing the B+ to 275V. Wattage output went up to 4.2W.... still really low! I measured the input voltage, while putting my scope on the output of the first gain tube - at .8V input it starts to clip the top of the waveform. This tube is biased currently at -6V on its grid. What am I missing here??? Why would .8V be clipping the amp?
#8 |
Did I also mention that the output stage is in ultralinear mode? Using the Hammond 1609 output tranny, with 40% screen taps. Although, this should be acheiving the same (or just under) wattage output as a normal pentode scheme.
#10 | |
Joel,
Have you tested the tubes as well? Rgds,
Frank |
| Amp. troubles PLZ HELP!!!! | ReverB | Car Audio | 5 | 1st November 2009 01:11 AM |
| Sound troubles | bamera | Chip Amps | 8 | 21st November 2007 03:22 AM |
| Zapdac mk3 troubles | ghisdal | Digital Source | 0 | 2nd September 2007 07:15 PM |
| SW troubles... PIA | nunayafb | Multi-Way | 7 | 30th March 2006 12:04 PM |
| amp troubles | squid6 | Tubes / Valves | 5 | 8th July 2004 06:50 AM |
