diyAudio Sponsor
Old 12th January 2006, 05:30 PM   #1
Question 81 Rectifier
Hello Diy members,
I have two pairs of big st style 81 rectifiers and want to use them in my new 5842 dc 45/46 tube amp.
For the powersuply i want to use the Psu designer from Duncan ,but there is no 81 rectifier in the list .
Which rectifier can i choose who comes closest to the 81 .
Regards Martin.
Old 12th January 2006, 06:31 PM   #2
TAccording to my RC-16, the type 81 is a half wave rectifier with a 7.5 volt 1.25 A filament. it's ratings are PIV 2000 max, Peak plate ma 500 max, dc output 85 ma max. Unfortunately it doesn't list any similar tubes. But At least you can find info on it, I have a Rodgers 2X3, that I can't find any info on.
Give a man a fish and he'll eat for a day. Teach him to fish, and he'll sit in a boat all day long drinking beer.
Old 12th January 2006, 07:29 PM   #3
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
It is a half-wave rectifier, like a single diode. You will need both of them to build a power supply of course.
So you could possibly think of the pair as equivalent to a type 80, which is like a lower powered 5Y3 I think.
Nice looking things! Just don't go too much above 250V with the voltage and use a small input capacitor, should last for decades.
Old 12th January 2006, 07:44 PM   #4
An idea: connect 2X 81 filaments in series, energize the series assembly with 15 VAC, and take the B+ from the junction of the 2 filaments.
An 80 is = 5Y3; the base is UX4. Max. value cap. for an 80 is 32 muF. 15 muF. should be safe enough for a pair of 81s, while keeping the rail voltage up.
Eli D.
Old 14th January 2006, 01:54 PM   #5
jlsem is offline jlsem  United States
jlsem's Avatar
These tubes have a considerably higher resistance (read large voltage drop) than almost any other rectifier. Look for a loss of 80-90 volts in your application. I don't like these tubes because whenever I would rummage through boxes of tubes at hamfests and swapmeets, I'd think that I had found a type 50 and it would always turn out to be a lowly type 80.
John
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
6CJ3 rectifier or 6D22S rectifier 56oval Tubes / Valves 10 19th April 2007 09:48 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Now that's a rectifier... Stuart Easson Parts 6 17th November 2004 07:37 PM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.07441 seconds (74.26% PHP - 25.74% MySQL) with 10 queries
