SE EL84 circuit for bi-amp setup?
Old 10th January 2006, 10:08 PM   #1
mholz is offline mholz  United States
Default SE EL84 circuit for bi-amp setup?
I'm interested in building a set of speakers pairing the CSS wr125 with a (cheap) ribbon tweeter, probably the Aurum Cantus G2Si. However, given the sensitivity differences between the two, I figured this might be a good time to try a biamp setup with my Fisher 500C.
Before tackling the xo issues, I need to find a circuit for the high end (above 3k). Does anyone have any recommendations for a SE EL84 circuit? I've got some salvaged iron I'd like to put to use.
And any suggestions for the xo? At this point I'm thinking Rane's SAC 22 might be worth checking out, though it's a much more expensive option than, say, a PLLXO.
Many thanks!
Old 12th January 2006, 02:59 AM   #2
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
I have savalvaged iron too and I am planning a simple EL84. Attached is a good start. If you are only driving a tweeter, you can likely get away without that capacitor. The resistor needs to be 1W.
Old 12th January 2006, 04:48 PM   #3
Eli Duttman is offline Eli Duttman  United States
Guys,
The salvaged "iron" is fine. Think long and hard about pentode mode, as Loop NFB is mandatory.
Life gets SIMPLER if you triode wire. Is the 2 WPC or so enough for your purposes?
Eli D.
Old 17th January 2006, 02:27 AM   #4
gmilitano's Avatar
Default Switchable Pentode/Triode
Originally posted by Eli Duttman
Guys,
Another option may be to put the amp together so you can switch between pentode and triode. A couple of resistors and switches should do the trick.
Gio.
Old 17th January 2006, 06:53 AM   #5
Valvewizard is offline Valvewizard  Yugoslavia
its a good idea
Old 17th January 2006, 03:29 PM   #6
many thanks for the tip!
SE EL84 circuit for bi-amp setup?Hide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
How would you improve this EL84 SE circuit? 4season Tubes / Valves 26 3rd July 2009 02:37 PM
EL84-PP - Why just 5W? Danko Tubes / Valves 25 22nd October 2005 03:57 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
el84 help inquisitive Tubes / Valves 14 26th March 2005 07:19 AM
