Photo Gallery
Photo Gallery
Old 26th June 2018, 01:02 AM   #8361
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
I have seen so many well polished amps here that I could not resist.
Old 28th June 2018, 06:49 PM   #8362
hectori is offline hectori  Chile
Other Projects finished
7591A PP Design
45 SE With D3a and 83 Tube
Phono Preamp (With my also DIY Garrard 401)
Old 29th June 2018, 12:35 PM   #8363
lexx21 is offline lexx21  United States
Photo Gallery
Geez Hectori.....is there anything that you don't build to absolute perfection? You have done amazing work!
Old 29th June 2018, 04:28 PM   #8364
Carlp is offline Carlp  United States
Photo Gallery
7591A PP Design
Wow, nice!
Old 3rd July 2018, 05:08 PM   #8365
sunil is offline sunil  India
Beautiful Hectori
Old 3rd July 2018, 11:43 PM   #8366
mhouston is offline mhouston  Australia
mhouston's Avatar
DHT2009, very neat. Looks pro.
Old Today, 12:32 AM   #8367
Mr_Zenith is offline Mr_Zenith  United States
Mr_Zenith's Avatar
Photo Gallery
Default Thomas Mayer Monoblocks
Hello all,
I finally completed my first build in nearly nine years, a pair of monoblocks built to Thomas Mayer's "Low Cost" design. Despite its origins as an economical build, I simply viewed this as an engineering exercise; the money not spent on interstage transformers went toward decent OPTs, top-notch hardware, and beefy construction.
Chassis is quilted maple with bubinga feet and trim; top plate is 0.180" thick aluminum. All fasteners are 18-8 stainless, and the tube sockets are genuine Johnson ceramics picked up from local hamfests. The OPTs are a pair of James 6123s I purchased from a member of another forum. All wiring is point-to-point with 14 gauge solid copper wire used as a ground bus.
The large box at the rear of each conceals an Antek AS-1T350 toroidal transformer, which is mounted vertically on an aluminum 'L' bracket due to space constraints. They're absolutely perfect for this project. Both amps have a combined weight of 55 lb. (20.4 kg), and took four months of work.
Was it worth it? You bet - these things sound absolutely incredible! This was my second SE project, and I wasn't disappointed. Thanks to Thomas for sharing this design!
Old Today, 01:07 AM   #8368
Mr_Zenith's Avatar
Photo Gallery
And a quick shot under the hood...
Old Today, 01:09 AM   #8369
jdrouin is offline jdrouin  United States
Wow, they look gorgeous Mr_Zenith? What’s the tube compliment? I think I see a 6N7 but can’t make out the rest.
Old Today, 01:29 AM   #8370
Mr_Zenith's Avatar
Photo Gallery
Thanks! I'll do you one better - the entire design can be found here.
Don't let the simplicity of the schematic fool you: this circuit is excellent. The bass is tight and controlled, and the mids/highs are neutral, as they should be in a well-designed SE amp. And the power supply is dead silent. This is not an "effects box" by any means.
BTW, the only changes I made to the schematic were omitting the ground lift switches and adding a CL-90 to each PT primary to control warmup. However, I will warn anyone reading this that there's another reason besides cost that most stereo builds aren't monoblocks. The effort involved is more than twice that of a single-chassis build - especially if you're building mirror-images.
Photo GalleryHide this!Advertise here!
