Photo Gallery
Photo Gallery
Old 11th April 2018, 01:36 PM   #8271
Brice is offline Brice  United States
Very nice.
Old 11th April 2018, 06:19 PM   #8272
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Originally Posted by Profi View Post
my lovely work: SE 6p3p-se
Love those tubes. Have a bunch of them and am eager to use finish my 6P3P-amp.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 15th April 2018, 06:58 PM   #8273
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Photo Gallery
Extraordinary Beautyful Amp Congratulations
Amazing how perfect You did schem picture on the wood.
Was made with CNC laser machine or something different technique ?
Cute amplifier ! Best regards
class A amplifiers with full range speakers
sings like angels in heaven
Old 15th April 2018, 07:00 PM   #8274
6L6 is offline 6L6  United States
6L6's Avatar
Photo Gallery
Profi - Absolutely wonderful construction!! Well done!
Old 15th April 2018, 10:40 PM   #8275
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Originally Posted by stevenrotterdam View Post
But where is the anode resistor?
Ssshhhh...!
Don't spoil it.
It's a work of art, and a missing resistor, while technically not correct, really doesn't take away from the effect created.
Old 17th April 2018, 01:16 AM   #8276
Bigun is offline Bigun  Canada
Bigun's Avatar
Photo Gallery
Originally Posted by head1962 View Post
my latest 300B's
with ECC81 Telefunken pre stage current sources in anode and cathode
extremely quiet. almost 9W before clipping
My search may finally have ended - I've been trying to find the name/type of a numerical display unit I had once as a kid. I liked to take things to pieces and this one was lost. It was a stack of perspex sheets with indents which light up when you put a small incandescent bulb to the edge. So the perspex sheets were formed into waveguides so a bunch of bulbs at the back of the unit would be used to select which number would be illuminated. Well it just looks like you have a pair of these on your shelf - I can't be sure but I would love to know what they are called, who made them because I forgot.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th April 2018, 05:25 AM   #8277
Hearinspace is offline Hearinspace  Canada
Photo Gallery
Is this the sort of thing ?
Old 17th April 2018, 07:14 PM   #8278
head1962 is offline head1962  Switzerland
I'll have a look on thursday, not at home now. they look very much like the one in hearinspace post. but they are modular. I found them in a military junk shop. they work.
Old 17th April 2018, 09:56 PM   #8279
Bigun's Avatar
Photo Gallery
Yeah, that's the right technology indeed. The one I had was a single digit, it was modular. The plastic waveguides were bent though 90 degrees so that their edges were available at the back of the module for all the little light bulbs - I think. Anyhow, thanks for the trip down memory lane, must have been 45 years ago !
Old 9th May 2018, 03:49 AM   #8280
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
My '82 280ZX had a similar display in the dash to warn of the various conditions like low coolant, wiper fluid, etc. Was really cool. It also had a little record player that vocalized the warnings too.
Photo GalleryHide this!Advertise here!
