Photo Gallery
Photo Gallery
Old 28th February 2018, 06:56 PM   #8231
adam1016 is offline adam1016  United States
acamilicko, that's one of the most beautiful amps I've ever seen. I wish I had those design skills, but my amps are always a utilitarian metal plate on a wood base, similar to bottlehead designs. What's the next step up from that without going full out custom metalwork?
Old 1st March 2018, 11:01 AM   #8232
acamilicko is offline acamilicko  Serbia
acamilicko's Avatar
Hey Adam, thanks for your kind words. This is mine very first tube device, and I was really trying to go away from standard bottlehead design.. You can view more detailed images on link I provided to our local diyaudio forum how it is built.
A wooden frame is actually made out of ash tree, inside of it is a plate holding PCBs, some are upside down and preamp PCB is attached to top, but normal. Not any metal work done, I have in neighborhood a plexiglass cutting store so it is all done there, front plate, back plate, etc... So combination wood-plexi for all
Keep it simple!
Old 2nd March 2018, 05:26 PM   #8233
artosalo is offline artosalo  Finland
artosalo's Avatar
V8 with 8 x GU50. My friend has interesting project under construction.
http://www.valveaudio.fi/66339631
File Type: jpg i282037939695769051._szw1280h1280_.jpg (301.2 KB, 1022 views)
Old 2nd March 2018, 06:33 PM   #8234
russc is offline russc  England
What do the plug leads do?
Old 2nd March 2018, 06:47 PM   #8235
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
You need a suitable loudspeaker for that one:
V8
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 3rd March 2018, 06:36 AM   #8236
artosalo's Avatar
Heater supply leads, 12,6 Vdc.
Stunning !!
Old 3rd March 2018, 11:17 AM   #8237
That is what you call a ported design!
Old 12th March 2018, 06:29 PM   #8238
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Photo Gallery
Building a new version of Tower amp. 2x100W SiC SE, augmented by current and voltage. The same driver with Gyrator - loaded 6N1P and 6P15P.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 12th March 2018, 06:47 PM   #8239
Bigun is offline Bigun  Canada
Bigun's Avatar
Photo Gallery
My gosh, that's a heat-monster. What does 'augmented by current and voltage mean' - aren't all amplifiers augmented by current and voltage - or is this some kind of sliding bias thing ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 12th March 2018, 08:43 PM   #8240
Wavebourn's Avatar
Photo Gallery
No sliding bias, just modulated power source for the output JFET follower that keeps voltage across it stable, and a CCS load modulated by the signal itself.
Photo GalleryHide this!Advertise here!
