Photo Gallery
Photo Gallery
Old 9th February 2018, 12:48 AM   #8211
qiuchun63 is offline qiuchun63  China
Default my diy
M O D ? ? ? - ???? - ????
Old 9th February 2018, 05:12 AM   #8212
dch53 is offline dch53  Australia
Originally Posted by jayfree View Post
This is the improved Push-Pull Mullard EL34 tube amplifier circuit. The original uses the Dynaco A420 audio output transformers which have a primary impedance of 6600 ohms. The schematic is from the Dynaco Super Fidelity Output Transformers catalog. Obviously I didn't use Dynacos, and I used bigger caps in the power supply. My first tube amp, and I am very happy with it. Time to build another amp, now I have the confidence to do it.
Beautiful! Work of art!
Old 10th February 2018, 02:10 PM   #8213
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Originally Posted by ChrisP View Post
A Beovis Valley.
I was hoping to swap between PCL86 and EL84, so the output transformers are 10k a-a and I can drop a GZ34 in place of the 1st smoothing cap to drop the HT. The voltage was still too high for a PCL86 though so I've had to go for the EL84s. The HT transformer is just a 1:1 isolation transformer. LM317's as ccs set to 40mA in place of the cathode resistor. Toroidy output transformers mounted upside-down.
can you comment a bit more ?
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000Ķ
Old 10th February 2018, 03:50 PM   #8214
ChrisP is offline ChrisP  United Kingdom
The toroidyís? Well the cables tend to exit the toroidy's straight up, so I was expecting to have to cover them with some kind of shroud until I realised If I flipped them upside-down and cut a couple of holes in the panel where the cables exit the trannies then I can route the cables neatly into the chassis.
Iíve used rubber grommets and had to cut a grommet-sized hole in the transformers rubber mount to keep it neat. It works quite well.
This is an older pic with the pcl86ís still in place. This has a 50V toroidal transformer with a two transistor regulator providing 67.2V for the series heater chain (4xPCL86 & 2xPCC88). Since swapping to EL84ís Iíve switched to AC heating.
It's a great sounding amp. I was running an SE 45 but this EL84 amp has a much flatter response with my BC Acoustique Niger loudspeakers. Horses for courses I guesss?
Old 11th February 2018, 02:16 AM   #8215
gabdx is offline gabdx  Canada
Quite heroic wire twisting there, not to mention the gray rectangual caps. El94 is still too forgiving for my taste.
amplificateurslegrand.ca
Old 11th February 2018, 09:43 PM   #8216
raybies is offline raybies  Australia
Some tube glow...
Anyone know how I can get a tube with more blue glow, the left side doesn't glow, the right almost has an infinity symbol ∞?
Old 12th February 2018, 12:21 AM   #8217
mkane77g is offline mkane77g  United States
Always Learning
Photo Gallery
Turn up the heat
Old 12th February 2018, 03:14 AM   #8218
Originally Posted by mkane77g View Post
Turn up the heat
Uuuuhhh, that's some nice glow.
My tubes are already hitting ~240c (~440F) and heating the room; it's summer here... how hot do they need to go?
Old 16th February 2018, 01:09 AM   #8219
Danner is offline Danner
Fine business right there.
Old 17th February 2018, 11:02 AM   #8220
Profi is offline Profi  Russian Federation
One of my project 6p36s:
Photo GalleryHide this!Advertise here!
