Photo Gallery
Photo Gallery
Old 7th December 2017, 06:17 PM   #8121
KIVIn is offline KIVIn  Ukraine
KIVIn's Avatar
I have finished my new DIY tube amps
Old 7th December 2017, 07:49 PM   #8122
JoeAlders is offline JoeAlders  Netherlands
Jeeezzzz, how did you make those magnificent fronts?
Old 7th December 2017, 09:27 PM   #8123
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Photo Gallery
Velikolepno!
Except probably cages for Gu-50 tubes, to prevent damage.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 7th December 2017, 09:59 PM   #8124
KIVIn's Avatar
Thank you all!
Fronts made of glass using silk screen printing. If I've understand your question correctly =)
My amps have cages for all tubes.
also I built acoustics on 48 speakers, it sounds brilliant.
p.s.
sorry for my English
Old 7th December 2017, 11:58 PM   #8125
apnneto is offline apnneto  Brazil
Beautiful work ... congratulations !
Old 8th December 2017, 03:29 PM   #8126
Thank you all!
p.s.
Yes, you did understand me correctly. Can you tell some more about that "silk screen printing"? Are you coating the glass with some substance?
But again, beautiful work!
Old 9th December 2017, 08:20 AM   #8127
KIVIn's Avatar
My fronts are like McIntosh use.
McIntosh factory tour front 1
McIntosh factory tour front 2
About silk screen printing. I tried few methods but silk screen printing is the best, it allows using the backlight. And I can adjust its brightness by remote control.
Photo inside my amps
Old 11th December 2017, 06:19 PM   #8128
SVStube is offline SVStube  Ukraine
Default 6C33C SE monoblocks
ECC85-6AV5G-6C33C SE monoblocks
Old 12th December 2017, 11:10 PM   #8129
Bigun is offline Bigun  Canada
Bigun's Avatar
Photo Gallery
Vladimir you did very nice work !
Looking at the last two posts it seems the Ukraine is string a high standard!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 14th December 2017, 06:36 PM   #8130
Vigi77 is offline Vigi77  Italy
Hi all! Greetings from Italy!
This is the integrated amplifier of my actual setup, it's a single ended based on a 20B triode (one tube per channel), the rectifier is a 5U4G.
It's very simple but i like it.
Photo GalleryHide this!Advertise here!
