Photo Gallery
Photo Gallery
Old 14th May 2005, 07:30 PM   #601
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Photo Gallery
Default Re: SE 50EH5 Pentode Tube Amplifier
Originally posted by GG
Attached are a couple shots of my latest amp. It is a single ended 50EH5 pentode. You can visit my website for more info.
I do have to get at my Mark II version with the bigger OPTs.
Bas, except for the lack of bass (expected with my OPTs) it is a decent sounding little amp. here is mine...
http://www.t-linespeakers.org/tubes/SEP_50EH5.html
One of the readers of my site, built one, and later subbed in a set of Lundahl 2A3 OPTs (making it a $405 amp ) and said it wasn't all that far behind the 2A3... the single stage i'm sure plays a role.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th May 2005, 07:35 PM   #602
frugal-phile(tm)
planet10's Avatar
Photo Gallery
However, of the limited amount of old tube consoles and TVs that I have come across, the 50EH5 is the most common.
My sample size is much larger (n>50). Most common are EL84 SE by a fair ways. Other NA ones have 6V6 SE & PP, some EL84 PP, 6BM8 & ECL86 PP, 50C5 and 50EH5 is actually fairly uncommon. German ones also have ELL80 & EL95 SE & PP, ECLL800 PP, and i have one TFK EL84 PP. Occasionaly i'll see SE or PP 6AQ5. Japanese tape decks seem most often to have SE 6AQ5 or 6BM8. The Sony TapeCorder 500 has a lovely 6AQ5 SE with (i believe) Tamura output transformers. These have a 600 ohm tap for driving the heads which would be perfect for that subwoofer amp fed or to make a preamp with serious grunt.
dave
Old 14th May 2005, 07:58 PM   #603
ddz is offline ddz  Ukraine
Default Amplifier EF12 and EL6
First stage - TELEFUNKEN EF12 (triode)
Output stage - TUNGSRAM EL6 (triode)
You can visit detail descrpition (in russia):
http://www.zzxm.narod.ru/project/EL6/amp.htm
Old 15th May 2005, 11:28 PM   #604
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Cool Here's my piece....
Well, here's a few pictures of my latest project.
It's a 6L6GC ULPP amp now, but will replace those with KT88's when they are worn-out. I use a single 6J5G triode at the input coupled to a longtail ECC99 as phase-splitter. The PP stage is UL and kathode biased. My dad was so kind to make me the nice oak-wood chassis :-)
Greetings,
Kathode Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 15th May 2005, 11:31 PM   #605
6h5c's Avatar
Default Here's my piece...
This is what the inside looks like.
Old 15th May 2005, 11:35 PM   #606
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Very good looking job Ray! What is the pcb thingy you've got in there...a power on relay circuit?
Bas
PS...You are welcome to come and listen in Middenmeer to my 6c41c if you like...
If you can see the speaker cone move...it's not hifi.
Old 15th May 2005, 11:35 PM   #607
6h5c's Avatar
Talking Here's my old piece...
And this is/was my previous amp. The new one is definately an improvement :-)
Old 15th May 2005, 11:38 PM   #608
Looks like on your new amp you have the output transformers oriented differently with respect to each other?
Old 15th May 2005, 11:38 PM   #609
6h5c's Avatar
Default Thingy
Bas
Hi Bas,
Indeed, it's a delay for the +B voltage, since i'm using SS recitifiers.
Ray.
Middenmeer hey, that's not too far from Heerhugowaard.....
Old 15th May 2005, 11:40 PM   #610
Let me guess the first one was built with Klare stuff and your second one with AE Europe stuff.
Nope..it's right around the corner. The guy that winds Klare's transformers also live in Heerhugowaard.
Photo GalleryHide this!Advertise here!
