#591 |
I also use oil tanks in my psu's.I tend to use ASC or GE.Built 7 amps including a preamp and keep learning with each one.As I said b4 nice work.
#592 |
"I also use oil tanks in my psu's"
As promised here's a photo of my latest prototype:PSE 2A3 direct coupled driven by 6n7's in parallel.Psu consists of 3 10H chokes and absolutely minimal ripple.Sounds amazing,detailed,open and with bass to die for.Gonna do a decent looking version now I've ironed out the teething troubles.Balanced out at 115mA per channel on the output section and 5mA per channel on the 6n7's.DC filament supplies on the input AC with humpots on the output.Will post the schematic as soon as I've drawn it. |
#593 |
Attached are a couple shots of my latest amp. It is a single ended 50EH5 pentode. You can visit my website for more info.
First picture - Front
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#594 |
Last Picture - Back/side view
There are a few more picture on my webpage.
#595 |
Gentlemen, have you children ? Are in Canada the same safety regulations, like in rest of the world ?
#596 | |
Safety in Canada? Sure ... the amp is grounded, the heaters run off of the mains (not the wall socket) and it is fused. The hot tubes are much safer to children (or cats) than an hot element on a stove or candle / scent pot on a table.
#597 |
By stove child know, that it is hot, by tube probably not.
Safety regulation for home electronic says ( and I hope that in Canada is it also the same ) : " Any by finger touchable part must not have temperature over 60 °C ". I recomend to you read some safety norms - they are not for joke .
#598 | |
diyAudio Moderator Emeritus
One does not hear often of folk building 50EH50 amps...
How does it sound? Regards, Bas Quote:
#599 |
Inside of pot aren't 500 V DC
#600 | ||
Indeed, the 50EH5 is not common. I have only seen two other 50EH5 amps on the internet thus far. You can link to them from my webpage. However, of the limited amount of old tube consoles and TVs that I have come across, the 50EH5 is the most common.
