diyAudio Sponsor
Old 28th September 2003, 04:37 PM   #51
Aonther try of my amp with picture.
Regards.
Old 28th September 2003, 04:50 PM   #52
X.G. is offline X.G.  China
X.G.'s Avatar
Default my tubes pre-amp in testing
and adjusting
Old 29th September 2003, 10:43 AM   #53
WD40
very glad to see your masterpieces shown on this site. You are too miserly to display your amp. colletion on NiuShiFu, though nearly every old man there knows that you are hiding a goldmine. When will your 813 venture be finished? I am looking forward to a surprise. Here is my mahine which is not much satisfactory and I use it as a testing one. With OPT input resistance as 2.5K, it can be powered by a couple of Shuguang 6P3PJ, the cheap equivelant of 6L6, or four 6P6P, the equivalent of 6V6GT, two each channel. The driver is 6N2, a tubel close to 12AX7. Well, the sound effect is, how to say, just so so, perhaps for the quality of OPT, with high distortion in the high frequency band. This is what I ever mentioned to you.
Old 29th September 2003, 10:45 AM   #54
The continued.
Old 30th September 2003, 03:08 PM   #55
wd40 is offline wd40  China
wd40's Avatar
Hi
My FU13 ( 813 ) SE AMP as before is living to test , and the wish be able to be completeed as quickly as possible .
Photograph when this is testing .
My english is very poor.
Old 30th September 2003, 03:21 PM   #56
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi WD40,
Does your 813 amp sound good? And do you have a schematic?
Bas
Old 30th September 2003, 05:10 PM   #57
wd40's Avatar
Hi Bas Horneman
It is right that the voice of 813 self is feel . For nevertheless quiz phase , the integrated schematic is not still completeed . Is 12AT7 SRPP>EL34 ( T ) >813 ( T ) now .
Old 1st October 2003, 07:02 AM   #58
jim is offline jim  Belgium
Default My PP807
Jim
Old 2nd October 2003, 02:48 AM   #59
PassFan is offline PassFan  United States
Default P-P 6L6
Here is my new one which is still burning in.
Old 5th October 2003, 06:09 AM   #60
wd40's Avatar
813 SE amp.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
jacobthellamer, vconsumer
Page generated in 0.12279 seconds (67.05% PHP - 32.95% MySQL) with 11 queries
