Photo Gallery - Page 592 - diyAudio
Old 9th February 2014, 08:07 PM   #5911
McGyver is offline McGyver  Poland
McGyver's Avatar
Originally Posted by bekim View Post
Aikido preamp.
Driven by 6N1P and 6N6P, output caps K40Y9, after few months I will change caps with Auricap's which I have them already.
Is there a Denon DCD-685 CD player? If so, it is worth to rebuilt.
You can replace its poor opamped analogue stage by tube based one, and the player will sound awesome. I did it many times, and recommend it for you. Here are some pictures:
Old 9th February 2014, 09:28 PM   #5912
bekim is offline bekim  Albania
You can replace its poor opamped analogue stage by tube based one, and the player will sound awesome. I did it many times, and recommend it for you. /tuB8yGZxoD50GcKV_VHY0fr6Jxg_BV7BSbE-UrMMZzE=w800-h461[/IMG]
Yeah DCD 685... Works good, just sometimes CD drawer get stuck, like is trying to open and after many times open/close will open or a "gentle" slap in chassis, the drawer opens :-)
Nice work in your cd player, which tubes you are using? I can see in pcb SRPP.. (will you share the design) Can 6N1P or 6N6P do the job?
My Aikido, I like sound of it. Really its worth any cent I invest on it.
Makes music so rich and lifelike, especially classic rock when I listen.
Old 9th February 2014, 09:39 PM   #5913
mhouston's Avatar
McGyver: nice upgrade mod to the player. I have a Teac PD-C400 5 CD player which I reckon sounds good as is. But modding the output stage to a tube stage would make it just a little nicer.
Old 9th February 2014, 09:48 PM   #5914
McGyver's Avatar
I'm using 6DJ8.
It's only print on PCB. My circuit is common cathode tied to the cathode follower. I'll share the circuit when I'll find the drawing. You can use (with some mods) the line stage from Klimo Merlin preamplifier also.
Yes, they can, but I dislike both. I used to replace 6N1P by 6CG7 and to replace 6N6P by 5670 or E182CC (Warning! Different pinout!). Replacing 6N6P by E288CC in my ukrainian monoblocks gave great sonic benefits.
I believe you. I'll post the pictures of my handmade tube preamplifier soon.
Old 10th February 2014, 01:34 AM   #5915
McGyver's Avatar
Promised photos of my tube preamplifier:
Tube stage:
Signal capacitor:
(will be replaced by Audyn True Copper when it arrives)
BJT regulated PSU:
Remote control module, it is programmable, works with any RC5 or RC6 RCU:
Rear panel:
...and finished unit:
Old 10th February 2014, 07:51 AM   #5916
hello ,
me old proto to new box , only use old components for build .
power finality = 2 x 5 w to 1 Khz at 8 ohms !
the clone perfect is build to good component
the price to build ...very little ; 50 dollars approximatly
File Type: jpg S.O.D.E.L Proto PL504 - 12AT7 - 2 x 5 W.JPG (246.7 KB, 612 views)
Old 10th February 2014, 10:21 AM   #5917
Great!
I check your site, very nice gear you build.
regards,
bekim
Old 10th February 2014, 02:18 PM   #5918
McGyver's Avatar
Great!
regards,
bekim
Thanks. Tube RIAA preamp inspired by Audio Research SP6 is the next piece on my workbench.
Old 17th February 2014, 05:35 PM   #5919
romicap is offline romicap  Romania
romicap's Avatar
Default Ampli SE config.2 x 8W
My SE amplif (paralel)2 x6P6S and ECC83 driver.
Old 17th February 2014, 09:38 PM   #5920
mhouston's Avatar
Romicap: looks good.
Copyright 1999-2017 diyAudio
