Photo Gallery
Photo Gallery
Old 23rd July 2013, 10:31 AM   #5321
dovla is offline dovla
Default One when stationary and one when traveling
For desk use (4-5 hours/day) EL84 SE that is usually operated single-stage (input from USB soundcard straight to trioded EL84 with 98db OB speakers 1 meter away) but can be switched to 2-stage if required.
For travel, all direct-heated headphone amp that plays for some 9 hours hours on one battery charge.
If not obvious from the pictures, both were made mostly of junk parts (but the labeling on the headamp 'housing' fits quite well ...)
Old 23rd July 2013, 10:43 AM   #5322
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar Photo Gallery
Dovla,
Can you share the schematic of your headphone amp? Is it the one on picture with miniature tubes?
Old 23rd July 2013, 10:56 AM   #5323
Originally Posted by yagoolar View Post
Dovla,
Schematic is in this thread http://www.diyaudio.com/forums/tubes...able-fits.html
Old 26th July 2013, 08:13 AM   #5324
tcqanh is offline tcqanh
Originally Posted by kevinkr View Post
Simple all transformer coupled stage design using a single GM70 and triode connected D3A per channel.
Hi Kevin,
I've heard this formula D3a-GM70 SE in my friend's system. Sound is a bit harsh, not much warm, rich tone... like traditional SET amp.
Is it enough gain for GM70 (over 200Vp-p) ?
Old 26th July 2013, 11:21 AM   #5325
kevinkr's Avatar
Photo Gallery
Mine is very pleasant to listen to without being particularly euphonic.. Actually in class A1 at 1kV about 160Vpp is all that is required.
Significantly less than 1Vrms is required to drive it to full output.
IT is 1:1
Opt is 7K:8
D3A runs at 20mA, GM70 at 120mA..
Currently using graphite plate GM70s.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th July 2013, 01:49 AM   #5326
IT is 1:1
Opt is 7K:8
My system has the same formula with you: DHT pre amp --> power amp including penthode tube in triode mode- IT- power tube.
Old 29th July 2013, 11:49 AM   #5327
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Photo Gallery
shape of things to come.... 8)
EL34 PSE...
6V6 pp amo...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 29th July 2013, 12:57 PM   #5328
loudnoise is offline loudnoise  Canada
loudnoise's Avatar
Hi, I have a pair of new GM70 but do not have any plan to use. Do you want to take it for free?
Old 29th July 2013, 03:40 PM   #5329
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Photo Gallery
Thanks god this topic doesn't disappear and I m still receiving some good impressions and news from anybody that is making something beautiful in this world. The summer now in Menorca is a fresh and clear balsamic water.
Esteban Bikić
Old 30th July 2013, 01:27 AM   #5330
Just met minhhp6365 at Thivan last week, so I known you did move your home. Your 4D32 PP mono block look so nice . How is new life ?
Tks for your kind! How do I get those GM70s ?
Photo GalleryHide this!Advertise here!
