Photo Gallery - Page 512 - diyAudio
Old 19th May 2013, 12:26 PM   #5111
Originally Posted by HiGHFLYiN9s View Post
Just finished up a special Bottlehead Crack build I call the Coppermine Crack.
Very cool looking! Great job!
I hope it sounds just as good.
Old 19th May 2013, 07:27 PM   #5112
grigrez is offline grigrez  Russian Federation
Hi guys. My first headphone amp
Old 19th May 2013, 09:19 PM   #5113
HiGHFLYiN9s's Avatar
Originally Posted by tomchr View Post
I like the copper. Did you do anything to prevent it from tarnishing? Clear coat?
I went with a satin clear coat from Krylon, had to wear gloves when handling the plate to keep the oils from my hands from getting on it.
My DIY Electronics Blog: DIYAudioBlog.com
Old 20th May 2013, 01:35 PM   #5114
Cassiel is offline Cassiel  Libya
You're no Rembrandt but the frame is nice.
Old 20th May 2013, 04:07 PM   #5115
soundbrigade's Avatar
Send a message via MSN to soundbrigade
That looked cool!
Either the tubes are big or the box small, so please let us know - what tubes have you been using?
After redoing the guts of my 5998A-SE and swapped to a big and yellow knob it looked like this. Got an 5998A-PSE on the way.
The marks around the ECC81 was done by the alu-ring (similar to the one around 5998A), but the socket was a bad apple and the new one didn't mach the ring.
(I have started to name my projects after Russian cities)
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 21st May 2013, 12:17 AM   #5116
Default My latest amp.
ECL86 SE mono amp. Built in one day. I've been away from SE amps for a while, got tired of them. On my 43th birthday nostalgia kicked in (my first amp was a PCL86 SE) so I built this to rememorate past feelings. Turns out I love its sound.. Haha, audio is a neverending story. Special features: UL, no cathode caps, last filter cap is a big Solen poly.
Old 21st May 2013, 12:30 AM   #5117
mhouston's Avatar
Yes to build an amp in day is a real challenge. I have done it but had everything primed and ready to assemble. I'm a SE nut and lately moving back to SE ULs. I built one whole amp PS totally with Mundorf M-caps (polis) in the PS. Big and expensive but I feel it did add a special edge to the sound.
Old 21st May 2013, 12:47 AM   #5118
I have to say the chassis was already painted and semi ready.
Old 21st May 2013, 01:22 AM   #5119
mhouston's Avatar
Assembly in a day is a valid challenge.
Old 21st May 2013, 04:08 AM   #5120
AJT is offline AJT  Philippines
AJT's Avatar
yes, but we DIY'ers are not bound by budget or deadlines, i take deliberate my time, since ideas come as i go along, sometimes inspirations come when you are about to do something....
it is not the actual building that takes most of my diy-time, it is the planning and gathering of parts.....
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Copyright 1999-2017 diyAudio
