Photo Gallery
Photo Gallery
Old 13th May 2013, 06:20 PM   #5101
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by donnyab View Post
are they your own pcbs ?
Yep. They're for sale on my website.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 14th May 2013, 06:31 PM   #5102
Evenharmonics is offline Evenharmonics  United States
Do you have measurements by any chance?
Old 15th May 2013, 02:32 AM   #5103
tomchr's Avatar
0.2 % THD @ 1 W, 1 kHz
10 W @ 3 % THD, 1 kHz
Bandwidth (1 W, -3 dB): 7 Hz - 32 kHz if memory serves.
I'll follow up with THD plots at some later date in the Damn Good 300B thread: http://www.diyaudio.com/forums/tubes...-300b-amp.html
I need to get my measurement scripts tidied up first, though.
~Tom
Old 17th May 2013, 07:08 PM   #5104
HiGHFLYiN9s is offline HiGHFLYiN9s  United States
HiGHFLYiN9s's Avatar
Just finished up a special Bottlehead Crack build I call the Coppermine Crack. This build took a bit of work: I mitered and routed the wood base, then copper leafed it, which is a fun experience if you haven't tried it. The plate of the amp is 12" x 12" x 0.1" copper. Some changes from the stock build are the 6SN7 signal tube, the excessive use of film caps for power and coupling, and a pair of oversized chokes. Hope you enjoy the pics.
For a detailed rundown of the build and more pics, visit:
DIY Audio Electronics from Zynsonix.com: Bottlehead Crack Coppermine Edition
My DIY Electronics Blog: DIYAudioBlog.com
Old 17th May 2013, 07:15 PM   #5105
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Sweet.
Old 17th May 2013, 10:18 PM   #5106
mhouston is offline mhouston  Australia
mhouston's Avatar
Exquisite.
Old 17th May 2013, 11:41 PM   #5107
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Very nick where did you get .1 copper at 40 dollars ? every
I go it closer to 70.
Old 18th May 2013, 05:31 AM   #5108
Hi Thom. If I recall correctly it was listed on Amazon. Shipping ran a little extra though as it was a third party seller.
Old 18th May 2013, 05:55 PM   #5109
tomchr's Avatar
I like the copper. Did you do anything to prevent it from tarnishing? Clear coat?
~Tom
Old 18th May 2013, 11:56 PM   #5110
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Photo Gallery
^a thin coat of clear lacquer varnish....this is what i use on my pc's...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Photo GalleryHide this!Advertise here!
