Photo Gallery - Page 499 - diyAudio
Old 21st April 2013, 05:16 AM   #4981
azazello's Avatar
https://picasaweb.google.com/1095707...85456673117378
My favorite tube SE 2A3-RCA & E180F-Phillips & Hornes with Fostex FE206E
and my room...
https://picasaweb.google.com/1095707...00460015416338
Old 21st April 2013, 06:02 AM   #4982
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
Every time I see a 6C33, I think of a MiG. Wonderful looking tubes - I wish I could find an excuse to use one (too many projects in the queue already)!
My regular amp is a P-P ultralinear EL34 (Mullard configuration - 12AT7 input, 12AU7 phase splitter) that I built about 15 years ago. Solid state power supply & regulation of my own design w/ slow-start B+. I listen to it at least twice a week, and it's still on only the 2nd set of output tubes - the first set (Tesla/JJ E34L's) lasted almost 10 years, and the newer JJ's are doing pretty well so far.
- Chad.
Old 21st April 2013, 06:14 AM   #4983
balerit is offline balerit  South Africa
balerit's Avatar
Moscode:
Moscode amplifier - The Book Worm
Old 21st April 2013, 06:20 AM   #4984
p_ete2003's Avatar
I use 6AS7G OTL
Old 21st April 2013, 06:24 AM   #4985
larryldspkr's Avatar
Antique Sound Lab single ended KT88 in triode mode, 5 watts three inputs and a remote!
Larry
Old 21st April 2013, 06:59 AM   #4986
jane is offline jane  Norway
jane's Avatar
Most of the time I’m using a 6C33 SE:
Life is hard - Then you die.
Old 21st April 2013, 07:22 AM   #4987
Here's my daily amp - 4P1L PSE. My preamp is 26 and forms the rest of the gain. Everything is in filament bias and transformer coupled - no coupling caps, no cathode bypasses. I'm so in love with this amp it's not funny. It's so incredibly clean and detailed I can hear every little thing at low volumes. It's kicked out everything and anything from vintage amps to several 300b SETs to three different 2a3 PP amps. My first build was with Audio Note Trans 152 OPTs, and my present build is with O-netics OPTs which is even better, so I even have two of these amps now! I'm in love.....
Old 21st April 2013, 09:20 AM   #4988
Default Atmosphère S-40 with KT88, Made in France
Hello, I have got this Tube Amplifier but did not find any info on net. Its made in France.
It has 7 tubes per channel:
1 X EF86
2 X 6SN7
2 X KT88 (JJ)
2 X EL34B (TAD)
Does anybody know this amp and company who made it? Its a big monster, weigh around 35 to 40 kgs. Accuphase P-500 looks like a kid compare to it.
Old 21st April 2013, 10:47 AM   #4989
M Gregg is offline M Gregg  England
What power Transformer did you use?...You know I keep looking at this..
M. Gregg
Old 21st April 2013, 10:53 AM   #4990
Its interesting,
Because there must be something "special" about an amp to keep it as an every day use amp.. Building is one thing..listening to it for extended periods ..is another..
M. Gregg
Copyright ©1999-2017 diyAudio
