Photo Gallery
Photo Gallery
Old 19th April 2013, 05:01 PM   #4971
ovpopov65 is offline ovpopov65  Russian Federation
Thank you
Originally Posted by Bas Horneman View Post
Very good clean build! Looks great...did you do the paintjob yourself?
With the paint work is helped by friends from the body shop
Originally Posted by Miguel Lopez View Post
Do the anodized pieces are home-made?
If you mean the anode caps - I bought them on ebay
Old 19th April 2013, 07:45 PM   #4972
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Photo Gallery
Nice work!!!
No maestro es pintura similar martillado. No sir is no anodized, is enamel that looks hamerite"
Best Regards
Esteban Bikić
Old 19th April 2013, 07:57 PM   #4973
Miguel Lopez is offline Miguel Lopez  Cuba
Miguel Lopez's Avatar
Old 19th April 2013, 11:36 PM   #4974
mhouston is offline mhouston  Australia
mhouston's Avatar
Originally Posted by ovpopov65 View Post
Hello everyone!
Here is the latest creation. SE 6G2_EL36.
Nice
Old 20th April 2013, 09:34 AM   #4975
Sorry, did not understand ... : O
Yes - it is a hammer enamel painting. https://www.google.ru/search?q=%D0%B...2&ved=0CDkQsAQ
Originally Posted by donnyab View Post
ovpopov65,
is that stained plywood or hardwood ?
The body is made of MDF. Then glued over with oak veneer and painted with lacquer.
Old 20th April 2013, 09:33 PM   #4976
M Gregg is offline M Gregg  England
Default What is your every day tube amp?
Simple question,
What is your every day amp...post a picture..is it PP or SE/other..
How often do you use it?
M. Gregg
Old 20th April 2013, 09:49 PM   #4977
namesmeanlittle is offline namesmeanlittle  United States
namesmeanlittle's Avatar
crown 810 its good.... i haven't saved up for a better amp tubes i mean....
works well though... good clear sound not stylish and fancy distortion but its baddass
its industrial so running in a house with 3 small full range boxes it never clips... ever
but i can also never get half its power...needs 15volt diver
thing never gets hot, never screws up, very protected...
it was 1 of 40 in a ballpark
i wanna use it one day for subs, not as though it can't run something
in my car
zapco 50C
such good car sq
run it 60% to 100% all day everyday
small amp but detailed
i can stand 50ft away crank it up and it sounds good
sometimes a 49 general electric am radio is just down right cooler than the 100+ watts of sound around
Old 20th April 2013, 09:57 PM   #4978
flatheadmurre is offline flatheadmurre  Sweden
Most hours per day is played by this beaty on my workbench
In the livingroom still without a lid
Old 21st April 2013, 03:28 AM   #4979
scott17 is offline scott17
Right now it's my 12W6 PSE experimental. I like it. A lot.
Old 21st April 2013, 04:18 AM   #4980
tomchr is offline tomchr  Canada
tomchr's Avatar
I'm using a 300B amp of my own design (see my website for details). It's still sitting in the living room in "DeathTrap" configuration - i.e. as a prototype with exposed wiring. The chassis is slowly coming together. I have one final round of painting left to go, then it's assembly time.
The attached shows the second-to-final configuration using ECC99 as the driver tube. I ended up using the 6N6P. JJ 300B running 400 V, 80~85 mA.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Photo GalleryHide this!Advertise here!
