Photo Gallery
Photo Gallery
Old 17th April 2013, 12:42 AM   #4961
jervill is offline jervill  United Kingdom
Originally Posted by Reegal View Post
I would like to present my last effort:
new s.e. amplifier using 100TH driven by 2A3.
Three power supply tubes regulated, one for 100TH using 6C33C and two ( one per channel) using 6EM7 for 2A3 and input stage.
Cabinet made in solid wood machines with CNC with nice copper inserts.
Wow, looks like a brute! Well done! Do you have a schematic? Interesting to see what all those valves are up to.
Old 17th April 2013, 01:07 AM   #4962
multi is offline multi  Australia
Hi Tony;
Do you have a circuit for the 813 amp?
I built Peter Millets 813 triode amp using 12HG7's as the single driver..
thanks
Phil
Old 17th April 2013, 02:21 AM   #4963
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Photo Gallery
Originally Posted by multi View Post
Hi Tony;
thanks
Phil
i use the same basic circuit as Pete's minus the computer startup...
2 6ck3's in a hybrid fwb bridge provides about 1100volts at standy..
the 11HM7's has it's own B+ supply at about 440volts dc...
the operating point will probably be at 1kv at 80mA at idle...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 18th April 2013, 12:55 AM   #4964
Thanks Tony;
My 813 amp runs at 800 volts; i made a regulator to run the 12HG7 but blew it up, so need to remake. at the moment just using resistors to drop the voltage. Would be best to have separate supply.
I don't have the computer startup...
phil
Old 18th April 2013, 06:35 AM   #4965
TonyTecson's Avatar
Photo Gallery
in my case, i added an 0A2 gas reg tube to supply 150 volts to the pentode driver screens, being a separate B+ supply, i felt no need for a regulator to supply this stage...
to me controlling the screen and feeding it off a low impedance source is enough for low distortions, the plates can vary and not have too much effect .....
Old 19th April 2013, 02:00 PM   #4966
ovpopov65 is offline ovpopov65  Russian Federation
Hello everyone!
Here is the latest creation. SE 6G2_EL36.
Old 19th April 2013, 02:18 PM   #4967
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Very good clean build! Looks great...did you do the paintjob yourself?
If you can see the speaker cone move...it's not hifi.
Old 19th April 2013, 02:27 PM   #4968
Miguel Lopez is offline Miguel Lopez  Cuba
Miguel Lopez's Avatar
Nice work!!!
Do the anodized pieces are home-made?
Old 19th April 2013, 04:49 PM   #4969
With the paint work is helped by friends from the body shop
Old 19th April 2013, 04:54 PM   #4970
donnyab is offline donnyab
ovpopov65,
is that stained plywood or hardwood ?
Photo GalleryHide this!Advertise here!
