Photo Gallery
Photo Gallery
Old 25th March 2013, 10:29 PM   #4911
multi is offline multi  Australia
Default 572b amp
Push pull 572B amp using Sowter output transformer and c core power transformer.
Old 26th March 2013, 08:12 AM   #4912
Default GEC 4 X KT88 200 watt amp
GEC 4 X KT88/6550 200watt amp.{ needs new tubes.}
Old 26th March 2013, 09:36 AM   #4913
mhouston is offline mhouston  Australia
mhouston's Avatar
Multi: where in Australia are you from?
Old 26th March 2013, 09:50 AM   #4914
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Photo Gallery
Default 813 set
work in progress....opt's are being built....the 813 is wired as a triode running on 900volt plate at 100mA, on 6k:6ohm OPT, this amp uses the 11HM7 driver with g2 regulated using the 0A2 gas reg tube...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 26th March 2013, 06:26 PM   #4915
hpeter is offline hpeter  Slovakia
hpeter's Avatar
can you share the schematic? is it the 160 tube?
Old 26th March 2013, 11:24 PM   #4916
peterfarrow is offline peterfarrow  United Kingdom
Photo Gallery
Some pics of my first amp back in 1998, still using it today...
Old 27th March 2013, 10:17 AM   #4917
Parafeed813 is offline Parafeed813  Netherlands
Hey, my favorite valve
Keep us posted on the results. Do you have different brands of 813 / QB2-250 to try?
Old 27th March 2013, 01:44 PM   #4918
Vincent77 is offline Vincent77  Europe
Vincent77's Avatar
Very nice!
I see some ECL82 in push-pull... a gas regulator and its 6AS7G pass tube... two beautiful magic eyes.. what are the other tubes?
Old 27th March 2013, 04:29 PM   #4919
bonzo15011978 is offline bonzo15011978  Italy
Relly interesting!
I red wonders of this little tube (E/PL82): matched with E/PC86 as a preamp tube and in SE triode configuration can give the most beautiful 0,5w ever.
Or so it's stated on "high sensitive" a german book published about 11 years ago.
Can you share the scheme and your listening impressions?
Ciao!
Old 28th March 2013, 10:54 AM   #4920
Photo Gallery
Originally Posted by Vincent77 View Post
Very nice!
thanks!
Two pairs ECL82 in push pull, two EM71a magic eyes, ECC83 preamp double triode. 85A2 gas regulator as a voltage reference for another ECC83 running as a cascode error amplifier driving the grids of 6AS7G, both sections in parallel for a regulated PSU at 270volts 250mA
The pentode sections of the ECL82s are wired in ultralinear to a pair of Sowter 10W @ 15Hz OPTs (big for 10W to get the low end nice and flat), the triode sections of the ECL82s are running as a longtailed pair phase splitter.
Photo GalleryHide this!Advertise here!
