#481 |
Morning rdf:
No..never thought of using chassie as part of the circuit. I always just run ground wires from everything to the input ground....as you can see in the pic. Although now that you mention it the chassie would probably save a lot of wire. I see from the pictures here a lot of ways to improve on my mess in my next project. |
#482 | |
Regards Anthony
I like to stay current! |
#483 |
Don't want to imply massive experience so YMMV but I used ground plane on an amplifier project originally designed for direct connection to crystal pickups. The input sensitivity is 0.1 volt. It's very, very quiet. In this case a PBC was used for the ground plane, I never did figure out how to attach wires to heavy copper. Too much heat required, the best idea I could come up with was machine screws through the copper sheet and nuts for a compression crimp. Then I woke up.
![]() The next project looks like it's going to be an Aikido and no question the same technique will be used. |
#484 |
ehe
![]() the input/driver stage is designed by Curcio. I made the PCB by myself with Circad (www.holophase.com). Yes, the amp use negative feedback. |
#485 |
My new amp
4x 6ch6 in a ppp design with 6c4 as phase splitters, still havent desided what the inputtube will be on the final amp, the schematic said 6br7 but Im not happy with that.
Tubes 4 ever |
#486 |
Very nice - mitred woodwork that actually fits together properly
Jason |
#487 |
Nice symmetry you got going there.
Anthony
#488 |
Account Disabled
Very nice!
16 tubes!?!?
#489 |
Nice work, but have your children asbest gloves ?
#490 | |
frugal-phile(tm)
Upuppa... you are like a broken record... ![]() dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
