#4771 | |
![]() Hey, it seems to me pretty good, and I'm pretty picky. Not to mention that Tony almost always winding their own transformers. Can you? ![]() He's a true DIYer.
I do not suffer from insanity, I enjoy every minute of it. -Edgar Allan Poe I hate idiots, that's why my house has no mirrors. -Just me ? |
#4772 |
Well....isn't that rude from Vincent to say that....?....no matter how Tony "style" is?
...or maybe they are good friends....
"I'm glad I can build my own mistakes." https://picasaweb.google.com/115586837612433686520 |
#4773 | |
I don't think that's rudeness, it's more of a constructive criticism. I encouraged Tony to improve the looks of his creations. There is plenty of inspiration on this thread! |
#4774 |
Maybe by amateurish you mean *industrial looking*, that just happens to be my favoutite look.
Spartan and not a hint of tung-oiled rosewood in sight. Rosewood is for furniture!!. Even refined aluminium hewn from a mill/lathe is downright annoying. Most of the amps from the 50s like Lowther, Quad and especially Klangfilm had that industrial look. A thing of beauty is a joy forever: I think this the look Tony will arrive at very soon. If he can make a replica of these I will definitely place an order! |
#4775 | |
Esteban Bikic |
#4776 |
Sure. Here is the GM-70 SE amp that I've just (almost) finished.
My own schematic, but it's nothing really special. It outputs a measured 29W RMS before distortion shows. The first stage is a CCS loaded, LED biased D3a (the photos were taken with an E186F in that position). The D3a has enough swing to drive the GM70 into clipping. The GM-70 are fixed bias. They are constantly monitored by an Arduino microcontroller that I've programmed, which switches off the amp in case of problems. It also does soft start and temporisation, plus LED control to indicate status, problems or overload/clipping. OPTs are custom gapped (90mA) Lundahl LL1688. The supplies are in a separated chassis. There are no filtering chokes in my supplies - it's done with Mosfets and SiC Schottky rectifiers, including the 1050v GM70 supply. The kilovolt supply is not stabilized, only filtered; the 350v supply is stabilized, not regulated (I do not like the sound of regulated supplies). Together with Rod Coleman's filament supplies, this makes the amplifier absolutely silent, ear to the (95dB) speaker. It sounds great. |
#4777 |
Forgot to say this is my first big amp project, I only did headphone and guitar before. I think and hope the next one WILL look better!
#4778 | |
Of course our tastes are different. When I like somebody's work, I do not hesitate to congratulate them. And if I think there's place for improvement, I say that, too. No hard feelings. |
#4779 |
Are all the French as charming as you?
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#4780 | |
Esteban Bikic |
