Photo Gallery - Page 475 - diyAudio
Old 7th February 2013, 03:34 AM   #4741
AJT is offline AJT  Philippines
AJT's Avatar
Originally Posted by nvduybom View Post
@Tony :
Looks good preamp .
I think the sound may be better with carbon resistors , especially resistors signal .
i do use carbon composition resistors as grid stoppers......
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th February 2013, 10:20 AM   #4742
merlin el mago's Avatar
Originally Posted by Stixx View Post
My C3G spud headphone amplifier is finally finished and playing music.
- C3G triode wired running at 145V / 15mA
- Cathode bias with tightly matched Morganite resistors and BG N bypass caps
- (yes, there is still people preferring a conventional setup over LED bias , but only when Black Gates are used)
- Salas SSHV2 with LC prefilter
- DC heaters
- Lundahl LL1689 wired 18:1
- custom wound toroid mounted on top
- all the guts underneath
Absolutely dead silent (Pitch Black background... ).
Wow amazing work, congrats
Old 8th February 2013, 07:14 PM   #4743
finished my tube preamplifier
Old 8th February 2013, 08:45 PM   #4744
N4BBQ is offline N4BBQ  United States
N4BBQ's Avatar
Very nice on all the last photos posted. I love seeing them.
Old 8th February 2013, 11:04 PM   #4745
12B4A is offline 12B4A  United States
12B4A's Avatar
After tracking down a noise issue I finally got this one working. I won't say I'm done with it but it is going to stay this way for awhile.
6N1P Broskie CCDA driving TJ 205D parafeed. 205D is at 350V/20mA/-20V cathode bias. 6N1P is at 165V/5mA/-3V unbypassed cathode bias. MQ BCP-15 plate choke and EXO-35 iron (yeah I know...5k:8 on 205D...feels good man). Many parts were salvaged from previously dismantled projects so there's some battle scars underneath. If I could completely redo it I'd figure out a way to make the wiring a little more tidy but all things considered I'm happy with how it turned out.
Old 8th February 2013, 11:42 PM   #4746
mhouston's Avatar
12B4A: I like the 205's. Very nice build all round.
Old 9th February 2013, 01:13 AM   #4747
wlowes is offline wlowes  Canada
wlowes's Avatar
Wachtfels666 AND 12B4A.... Beautiful work. Thanks for sharing.
Old 9th February 2013, 02:01 AM   #4748
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Very nice build! But... why I don't trust cable ties holding heavy capacitors with high voltage on them, in hot environment?
The Devil is not so terrible as his math model is!
Old 9th February 2013, 02:36 AM   #4749
12B4A's Avatar
I used anchors with screws so no adhesive delamination (if you've had an accident with this method then please say so). The amp runs barely warm as well, a little less than 80VA total consumed on a 17x12x3 by 6mm thick aluminum chassis with vents directly over the resistors dissipating heat and holes in the bottom plate to allow convection path. 1 watt per channel output with 80 watts consumed, yes, almost enough for headphones.
Old 9th February 2013, 06:20 AM   #4750
Vincent77's Avatar
Wachtfels666, nice work! You should take a photo of the EM84s working!
12B4A: looks great! have you thought about painting the transformer cover white?
Copyright 1999-2017 diyAudio
