Photo Gallery
Photo Gallery
Old 28th January 2013, 06:20 PM   #4671
RK1 is offline RK1
Originally Posted by bayermar View Post
I think he is referring to safety ground.
Lifting that with a resistor (no matter what value) would violate all German electrical safety laws.
I can see only a single point where all the ground wires connect to the chassis - this is exactly how I do it, too. No problems with ground loops.
You could connect signal ground via a resistor with safety/chassis ground, but why if its dead silent? Don't fix it if it ain't broken...
Seeing the level of construction skills, I guess Stixx knows EXACTLY what he is doing.
Great piece of art BTW.
Martin
Probably you do not understand (or my englsh is bad )
My opinion has nothing to do with safety.
-> Casing (chassis), especially metal, it must be connected to the protective power (no resistor).
-> ElectricMass of the (mass supply) should be connected through a resistor to the protective power.
Have a nice day
Old 28th January 2013, 08:57 PM   #4672
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Photo Gallery
Originally Posted by Dimitris AR View Post
This is my new Tube preamplifier .
3 tubes ( two PCF200 and one EF183 ) on each channel , -3dB at 400KHz , gain 19.4dB .
Very nice!
Where did you get 10-pin sockets?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 28th January 2013, 09:08 PM   #4673
Wavebourn's Avatar
Photo Gallery
Originally Posted by Wachtfels666 View Post
my new preamplifier, still on construction but nearly finished:
She will definitely love it!
Old 28th January 2013, 09:11 PM   #4674
Wavebourn's Avatar
Photo Gallery
Originally Posted by Stixx View Post
My C3G spud headphone amplifier is finally finished and playing music.
- C3G triode wired running at 145V / 15mA
- Cathode bias with tightly matched Morganite resistors and BG N bypass caps
- (yes, there is still people preferring a conventional setup over LED bias , but only when Black Gates are used)
- Salas SSHV2 with LC prefilter
- DC heaters
- Lundahl LL1689 wired 18:1
- custom wound toroid mounted on top
- all the guts underneath
Absolutely dead silent (Pitch Black background... ).
Peace of art! Now wait for similar designs on the market.
Old 28th January 2013, 09:44 PM   #4675
jpak is offline jpak  United States
jpak's Avatar
Tube amplifiers with output transformers are better off with high impedance cans because of the availability of suitable transformers... --> see other thread on Diyaudio
Would you mind pointing me to the other thread?
Old 28th January 2013, 11:35 PM   #4676
Triodethom is offline Triodethom  United States
Triodethom's Avatar
It is worth repeating Stixx produce it your self before the PRC copies you. Regards
Old 29th January 2013, 06:12 AM   #4677
Stixx is offline Stixx  Germany
Stixx's Avatar
Thanks Wavebourn! But man how would I hate that...
Here you go --> http://www.diyaudio.com/forums/tubes...phone-amp.html
Unfortunately I have absolutely no means of producing this... apart from a few extra cnc parts
Old 29th January 2013, 02:58 PM   #4678
Cassiel is offline Cassiel  Libya
Default My transformer has grown a nipple.
I swear last night that area was flat. Painting toroids can be tricky. Just saying.
Old 29th January 2013, 04:58 PM   #4679
Stixx's Avatar
Must have been a hot night then...
Old 29th January 2013, 07:27 PM   #4680
mhouston is offline mhouston  Australia
mhouston's Avatar
It's alive.
Photo GalleryHide this!Advertise here!
