Photo Gallery
Photo Gallery
Old 27th January 2013, 04:37 PM   #4661
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Photo Gallery
Originally Posted by Stixx View Post
My C3G spud headphone amplifier is finally finished and playing music.
- C3G triode wired running at 145V / 15mA
- Cathode bias with tightly matched Morganite resistors and BG N bypass caps
- (yes, there is still people preferring a conventional setup over LED bias , but only when Black Gates are used)
- Salas SSHV2 with LC prefilter
- DC heaters
- Lundahl LL1689 wired 18:1
- custom wound toroid mounted on top
- all the guts underneath
Absolutely dead silent (Pitch Black background... ).
I just discover your Kunstwerk!
Esteban Bikić
Old 27th January 2013, 04:52 PM   #4662
Stixx is offline Stixx  Germany
Stixx's Avatar
What headphones do you use?
What headphones do you use? 300 Ohm?
Jpak, blackdod, for this one I am mostly using Senn HD800. Tube amplifiers with output transformers are better off with high impedance cans because of the availability of suitable transformers... --> see other thread on Diyaudio
The Lundahl perform very satisfying... very well worth the money.
I see you have reached your maturity as a amp builder, Stixx. Not much room for improvement now.
Dang, life will be getting boring then...
Hvala ti!
Old 27th January 2013, 05:18 PM   #4663
blackdod is offline blackdod  Europe
Ok, Thanks!!!
Im looking a new tube Amp for my Senn/Beyer (300/600 Ohm) but yours Amps have very good look.
Cheers
Old 27th January 2013, 10:29 PM   #4664
mhouston is offline mhouston  Australia
mhouston's Avatar
Stixx:beautiful build. Do have a schematic?
Old 28th January 2013, 10:23 AM   #4665
RK1 is offline RK1
- DC heaters
Good job.
I found one error
Supply protective conductor is connected directly to ground. It should be the resistor 10-100 ohm. This prevents the creation of ground loops.
Old 28th January 2013, 10:37 AM   #4666
mhouston's Avatar
Originally Posted by RK1 View Post
Good job.
I found one error
Snub the resistor with a cap too. I'm guessing 0.1uf poly.
Old 28th January 2013, 11:16 AM   #4667
Stixx's Avatar
Good job.
I found one error
Guys, I am at a loss. What is meant with conductor... the choke? This one is not conncted to ground, nor are any capacitors in the regulators... Clue me up please!
Old 28th January 2013, 01:01 PM   #4668
bayermar is offline bayermar  Germany
bayermar's Avatar
I think he is referring to safety ground.
Lifting that with a resistor (no matter what value) would violate all German electrical safety laws.
I can see only a single point where all the ground wires connect to the chassis - this is exactly how I do it, too. No problems with ground loops.
You could connect signal ground via a resistor with safety/chassis ground, but why if its dead silent? Don't fix it if it ain't broken...
Seeing the level of construction skills, I guess Stixx knows EXACTLY what he is doing.
Great piece of art BTW.
Martin
Old 28th January 2013, 02:06 PM   #4669
felixx is offline felixx  Romania
felixx's Avatar
Great work Stixx.
You need to be at Munich 2013 High End Audio in March.
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
Old 28th January 2013, 02:21 PM   #4670
Stixx's Avatar
Photo GalleryHide this!Advertise here!
