Old 3rd January 2013, 06:24 PM   #4581
heb1001 is offline heb1001  China
Default My first tube amp build
The minimum feedback version of this: The Emperor's New Amplifier with a balanced input stage.
Old 3rd January 2013, 09:20 PM   #4582
mhouston's Avatar
Impressive.
Old 4th January 2013, 02:22 AM   #4583
Hi
I have finally finished the latest incarnation of my 12AX7 RIAA preamp (wooden box near the Thorens).
Here you are two complementary pictures of my system.
Enjoy!
--Rodrigo.
Old 6th January 2013, 08:42 PM   #4584
scott17 is offline scott17  United States
scott17's Avatar
Default Exterior design gone horribly wrong...
The overall look did not really turn out like I expected, but it sounds fine.
6BG6-GA single ended, UL & triode, 6SN7 driver/LED bias, dual rectifiers.
Scott
Old 6th January 2013, 09:54 PM   #4585
mhouston's Avatar
Scott
Scott17:I like it.
Old 7th January 2013, 01:51 AM   #4586
Scott
Swap the knob for a chrome finish to match the capacitors and swap the protection around the switch to match the handles and it will look great.
Old 7th January 2013, 02:12 AM   #4587
6L6 is offline 6L6  United States
6L6's Avatar
+1
That's a very good idea to fine tune the looks!
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 7th January 2013, 01:45 PM   #4588
vermeero's Avatar
Default RH Universal
Pictures of my new build, the 'RH Universal'. Schematic by Aleksandar Kitic.
It's a single ended design allowing the use of various output tubes, but one could say it works best with the KT88.
More info on this amp is to be found at the forums of diytube and audiokarma.
By the way, it's sounds really great!
Old 7th January 2013, 02:01 PM   #4589
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Lovely!
Old 7th January 2013, 02:22 PM   #4590
scott17's Avatar
Very nice vermeero! What are the output transformers?
Copyright ©1999-2013 diyAudio
