#4551 |
#4552 | |
#4553 |
Here my last creation, 300B psvane in s.e.
Tubes power supply with 3B28 , hand made transformers including the output transformers. Vu meter made with EM83 Cabinet is made in solid walnut musical instruments wood and the top is made in ragged marbled wood with teak inserts, all are machined with CNC milling machine. Marry Christmas |
#4554 |
Reegal,
I always find your amps an inspiration. The wood work and layout is always exceptional..well done as usual.. ![]() Regards M. Gregg
What is the sound of one hand clapping? |
#4555 | |
Here is the schematic-create preamp and enjoy his sound! Cheers! |
#4556 | |
Please show the schematic to preamp 4S with tube/valve 12AU7 (ECC82) . thank you! |
#4557 |
4S Universal:
#4558 |
#4559 |
Gost22 This is not the "Black" schematic. If you want that I will post it too. They are slightly different.
#4560 | |
I love tubes and wood and I always try to do my best to match them with my ideas. Next will be an amplifier with 205 tubes. All the best Guido |
