#4531 |
Well, that little old scope served me for quite some time.
After a diy-break of several years I turned it on and it worked for about two minutes. Power light is on, but nothing on the screen. And I really need my scope now: I just finished the first mono of a new PP KT88. It is quiet, even on high efficient speakers, but I can't get stable AC readings on my DMM. ECC99 LTP with a LM334 CCS as the tail, set for 5mA, directly coupled to a 6SN7 driver (shared 12k cathode resistor, 8mA total). The KT88's running in triode @ 465V, driven by IRF820A's as source followers. |
#4532 |
I think you need to add gridstoppers on V1 and V2 to stop a possible oscillation.
Real tubes have top-caps |
#4533 |
"Menatzchim" C3m tube preamp in a 1UR enclosure with Jensen copper,paper and oil caps and silver leads. 3 switchable inputs on rear.
#4534 |
#4535 |
#4536 |
Each tube only has a single pentode. I recommend you don't use a Ck but if you do 150uf is the valve. A 10V version is sufficient. I used a 0.47uf Jensen copper, paper and oil cap on the output. According to the designer (Matt) it is OK to use 0.47 and not 0.33uf.
Thanks for the nice comment.
| "VoXDeuX" - Inexpensive two-way speakers | "VoXItBassO"- Stereo 12" sub-woofers |retro-34UL - Signature EL34 amp Last edited by mhouston; 17th December 2012 at 09:28 PM. |
#4537 |
Hey guys,
i also want you to show my KT88 Single Ended Amp. Its the best Amp i have ever build ![]() In the photos you can see 2 different rectifiers, i changed it finally to the bulbed version of the 5U4GB. A preamplifier is still in plan. |
#4538 |
A clean, solid build. What kind of finish is that on the plate (the one pic makes it look gold-ish) and what are you using for feet?
#4539 |
thank you. The feet are from an old computer case from Lian Li (link to picture: http://i1-news.softpedia-static.com/...-Support-2.jpg ) What do you mean with plate? The main plate of the whole chassis? That ist just alumium color, the heaters makes it look like gold
#4540 |
Hi folks
![]() This is my first job ![]() JFET direct coupled 6N6P push-pull with balanced input.. 6N6P_02.jpg 6N6P_03.jpg Last edited by ysk6253; 19th December 2012 at 03:37 AM. |
