#4511 | |
Hi, Classic style serious with a touch of blue aspect that match with any other device, definitively my style. Let me make a question, the output valves are 6NJ6 or 6JN6 ? Can you show the electronic diagram of it? Best Best
Esteban Bikic |
#4512 |
Tim, Anuha Shimika, Incredible finish at all, the bench the station the HIFI, Cool and amazing delicate touch. I guess that this monster sound like show. Classic, fineness the color and the finish. Witch Loudspeakers are them?
The best best regards
Esteban Bikic |
#4513 | |
Best Regards and congratulations at the end of era.
Esteban Bikic |
#4514 |
#4515 | |
yamaha ns1000
Tim |
#4516 |
Anuha Shimika?
what is that mean?
Tim |
#4517 |
Hi Tim, that mean How you doing in Korean language, actually is the noise of the word that I listen from a friend.
Sorry I guess you are descendant from This land. The best for you.
Esteban Bikic |
#4518 | |
She's audio vintage fan . PCB's gift of VNAV , and My project of the year
#4519 | |
I learn a new word, I grew up I'n the state but I am born I'n sai Gon Viet nam These Yamaha are great speakers, I didn't really care for them as first but they grew on me
Tim |
#4520 |
Deviating a bit from my original intent, of keeping things in chronological order- here's a set of amps and preamp which I built, that I just sold this morning.
![]() The amps started as a very rusted set of Dynaco MK III chassis, that I got in pieces. In fact, here's how bad they were to start with: ![]() Since I didn't get any transformers, I decided to experiment a bit. I have always been a big fan of 6L6 type tubes- so, I converted the design over to 6L6GCs. The output transformers are 6.6K 60 watt UL interleaved-winding Hammond units, and the power transformers were from a pair of Thomas organ amps. The feedback loop and bias circuits were re-worked to work correctly with the new tubes and transformers, and the power supply was converted to solid-state rectification, with much more capacitance than stock. Output is about 40w/ch, with 4 and 8 ohm outputs. ![]() The preamp was built from scratch, to be a close cosmetic match to the amp chassis. The phono stage is a modified Dynaco PAS type (using a bit of each of the Latino and Curcio mods, melded), and the line stage is a single-gain-stage buffered circuit, that I have worked up myself. It's completely point-to-point wired inside (no circuit boards), with a solid-state rectified power supply with DC heaters. ![]() It was a little sad to see these go, as they sounded SO GOOD (especially the mids- and they were SO dynamic). But, now I have resources to buy parts to build more amps! Regards, Gordon.
Speaker Design, Restoration and Repair- since 1985. |
