Photo Gallery
Photo Gallery
Old 19th November 2012, 03:51 PM   #4481
GordonW is offline GordonW  United States
GordonW's Avatar
I never got around to posting pictures to this thread, until now. Better late than never, I guess.
As I get time and the necessary combinations of parts and materials, I build amps in my home workshop. Mostly on a hobby basis- but I have wound up building and selling, both after-completion and on prior commission, various amps, over the last six years or so.
I tend to build mods and improved versions of some of the classic designs. As the great Isaac Newton said: "If I have seen further it is by standing on the shoulders of giants." Some of these older-generation designers were quite gifted- by learning and using the ideas they created, it paves the way for me to create my own ideas...
First off, the first amp I built from scratch. As in drawing the schematic, putting together the parts lists, punching and drilling the chassis, and assembling the parts. It's based on the classic Magnavox paraphase PP circuit, using 7C5 (loktal version of 6V6) output tubes:
Photo Gallery-loktalmaggie1-jpg
This started out as a blank rack-mount chassis, which I punched, drilled and painted. Power transformer was from a large color TV, and output transformers were from a Knight integrated amplifier (a bit heavier than the original Magnavox transformers, and with 4, 8 and 16 ohm taps). Input tubes are 12AX7s.
Photo Gallery-loktalmaggie4-jpg
In all, a satisfying 12 watts per channel.
Gordon.
Speaker Design, Restoration and Repair- since 1985.
Old 19th November 2012, 03:59 PM   #4482
GordonW's Avatar
Sort of keeping a chronological order- my second scratch-built amp was based on a recovered Pilot SA232 chassis (it had been in a fire). Chassis was stripped, polished, and re-drilled to fit the new components.
Photo Gallery-10-5-amp-front-view-jpg
The amp is loosely based on the Stromberg-Carlson ASR333, except simplified. This is an integrated amp, with three inputs, a 6CG7 input tube, 6U8 drivers and 6BQ5 PP outputs. Power transformer is again a color TV unit, and output transformers are from a hefty Seeburg jukebox, that originally used 6973 output tubes.
Photo Gallery-10-5-amp-lf-view-jpg
This turned out to be a little power-house of an amp- easily 17w/ch or more, with prodigious low bass output and quality. A friend of mine wound up with this amp- it actually booted an Audio Research CA50 integrated amp out of his system, if you can believe that.
Gordon.
Old 20th November 2012, 01:51 AM   #4483
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Congrats! very, very nice units, simple, compact, and superb classical look.
I envy Your ability to lay the wiring, and do the solder job in such a reduced space!
I think you're the guy that fellow member asking for "one skilled designer" was looking for...
"It is less serious than if worst"
Old 24th November 2012, 06:01 AM   #4484
tim614 is offline tim614  United States
tim614's Avatar
Default pp kt120
Photo Gallery-img_0767-jpgPhoto Gallery-dsc01389-jpg
Photo Gallery-dsc03627-jpg
pp kt120
Tim
" perfect imperfection "
Old 24th November 2012, 06:32 AM   #4485
56oval is offline 56oval  Australia
Hello Tim
Really nice looking setup . But your work bench is just to neat .
Cheers
Old 24th November 2012, 08:15 AM   #4486
mindutis is offline mindutis  Sweden
mindutis's Avatar
Very nice. I love it!
What are the loudspeakers you are using? Thanks.
Old 24th November 2012, 01:44 PM   #4487
tim614's Avatar
Originally Posted by 56oval View Post
Hello Tim
Cheers
neat!?
not all the time, that was cleaned up after i finish the amps
Tim
Old 24th November 2012, 01:45 PM   #4488
tim614's Avatar
thanks!
speakers are yamaha ns1000
Tim
Old 24th November 2012, 01:46 PM   #4489
tim614's Avatar
got a new mac, so i played around and made a video
PP kt88 slide 1 - YouTube
Tim
Old 24th November 2012, 06:58 PM   #4490
mhouston is offline mhouston  Australia
mhouston's Avatar
@tim614: Clean good looking build. Your whole set-up looks good.
Photo GalleryHide this!Advertise here!
