Photo Gallery - Page 448 - diyAudio
Old 13th November 2012, 04:49 PM   #4471
RK1 is offline RK1
Originally Posted by dady View Post
Incredible, what is this amazing devices? Please publish the plans.
I wanna them!
2 speaker - black
2 crossover (granite - black)
2 monoblok - tube PSE, kt 88, ecc 82, ecc83
1 preamp - tube SN7, ecc82, ecc83, RIAA
(all my design and construction)
Whole is not easy to do (except that it is patented). For example, casing has about a thousand laser-cut parts.
Have a nice day
RK
Old 13th November 2012, 04:55 PM   #4472
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Send a message via Skype™ to dady
Originally Posted by RK1 View Post
2 speaker - black
Have a nice day
RK
So exotic amp and speakers, Enjoy but please if is possible more details of the technical and the finish that is actually so beautiful.
Have you a nice day too.
Esteban Bikić
Old 13th November 2012, 04:57 PM   #4473
RK1 is offline RK1
Thank you.
Well, as I will have more time write.
Have a nice day
RK
Old 13th November 2012, 06:15 PM   #4474
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Originally Posted by fooeywuffle View Post
Not complicated. Output 60 watts a channel 0 db 20 Cy to 20 K Cy.
T.E.C. TRIODE AMPS
Just to point out - it looks like the bridge for the bias supply is reversed. It should be generating a negative supply but the diodes in the bridge as drawn would give a positive supply.
Old 17th November 2012, 06:06 PM   #4475
Default Parafeed SE 6550 / KT100 (EL156)
Finally found a moment to post my current amps.
They are two parafeed amps with external PSUs.
The amps have been running on 6550s until this week. Now I'm trying some old Valve Art KT100 (actually an EL156 with octal base).
Still not done with these amps, as there is a low level hum in one of the units. Unfortunately my little Russian scope decided it's time for its retirement, so I can't pinpoint the source of the hum. If I can believe my DMM it is only on the OT secondary, not its primary.
The PSUs deliver several filament voltages and three different HTs : 300V - 400V (regulated), 370V & 1kV. This way I can use it for more than one amp. Now I have just the two parafeed monoblocks, but I'm building a SE 6L6GC and a SE 813 guitar amp that will be fed from these PSUs as well .
Eventually two parafeed QB2/250 (euro 813) amps will see the light. Or better: bring light to the room
Old 17th November 2012, 08:23 PM   #4476
Triodethom's Avatar
I like them very clean and straight forward look.
Old 19th November 2012, 02:54 AM   #4477
Cassiel is offline Cassiel  Libya
Just found this on my computer and I think it deserves some exposure.
Old 19th November 2012, 03:15 AM   #4478
Oh and that thingy with the silly sunshade is a valve audio device too. Not finished yet....
Old 19th November 2012, 11:14 AM   #4479
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
Does it spin?
Old 19th November 2012, 02:25 PM   #4480
No spinning but it weeds out bad vibes from your system. Here's another voodoo idea to improve your sound and take some heat off:
Copyright 1999-2017 diyAudio
