#4441 | |
The little adjusting knob on the top of the pre adjusts the amount of feedback, enabling ripple to be tuned out to give a silent background. The OTL is so quiet that any noise added is immediately noticeable, The ripple killer makes sure there is no chance of noise creeping into the preampand it does regulating duties too. Yep the red looks great. Glad all of you like it. |
#4442 | |
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#4443 |
At the front of the preamp there is a black cylinder. This is a German C3g pentode, strapped as a triode. This is the shunt reg tube and it is this that does the antiphase ripple thing.
#4444 | |
#4445 |
It's a new PP 6550 60 Watts class AB amp made for my cousin.
Input tube is a 6n1p- EV, 6n6p as LTP driver with ixys 10m45s (18mA) and finally 6550 EH in UL. Va=465 Volts, fixed bias Ia=55 mA. Amp is running flawless till 60 Watts. Clip showed at 75 Watts. OPTs are Hammond 1650N and PT it''s a custom one winded on a 800 VA core Sound is full bodied and pleasant for a lot kind of music i listened. From Jazz till hard rock amp sounds great. Freq response at 50 Watts 25hz - 36Khz, 0db, Thd : 1.8% at 50 Watts - 1khz, 2.5% at 60 Watts - 1khz, no feedback applied. Think that all went great and 6n6p LTP looks like hell of a driver for PP purposes if current sourced. LTP Sin waves look absolutely symmetric both phases.. Quiet happy of the result. Sorry for the bad quality photos... |
#4446 |
#4447 | |
#4448 |
@aroS3: Take the spec. stickers off the OPTs. Nice build on a wooden base.
#4449 | |
Best regards, Thanks
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#4450 | |
Regards, George |
