Photo Gallery
Photo Gallery
Old 18th October 2012, 04:43 AM   #4381
mhouston is offline mhouston  Australia
mhouston's Avatar
@disco: can you show us the underside of the amp section. The amp on the thick timber work with just the tubes poking up.
Old 18th October 2012, 09:44 AM   #4382
disco is offline disco  Netherlands
disco's Avatar
Got the idea mate Here you go:
Notice the short distance between power tranny, choke and OT.
No hum, no noise at 100dB loudspeaker.
Those R-core can't compete with amorphous core
but are a decent bang for the buck. Mid and highs are nice.
Rod's filament supply is in the frontpanel, at the copper strip.
Coupling done with 1uF Audicap and two 0,1uF Cardas.
The TCC oil is a little inductive, fine for that first position.
Wiring between HT rectifier and first cap is shortest possible.
LV supply has been split in noisy front (near tranny)
and 'clean' end at the tube sockets.
Finishing the plinth is for today, as is tidying up wires.
jaap
Old 18th October 2012, 10:22 AM   #4383
andRookie is offline andRookie  Norway
Default Inspired by Allen Wright.
6H30 cascode (copy from AW)
EL34/ KT88 output, ccs bias
21st Century Maida Regulator on driver/ input.
5k OPT
Old 19th October 2012, 10:13 AM   #4384
RK1 is offline RK1
example
Old 24th October 2012, 04:45 AM   #4385
56oval is offline 56oval  Australia
Originally Posted by RK1 View Post
example
Very tasty ,a over head shot please
Old 24th October 2012, 09:18 AM   #4386
mhouston's Avatar
example
Does look good. Better images please.
Old 24th October 2012, 04:58 PM   #4387
RK1 is offline RK1
one of the last photos (with speaker)
T?umacz Google
Old 25th October 2012, 08:58 PM   #4388
Steve Cresswell is offline Steve Cresswell  United Kingdom
Steve Cresswell's Avatar
Here is my latest project.
It is my take on the new Transcendent "Son of Beast" output transformerless tube amplifier.
The design was built from the circuit that appears in Bruce Rozenblit's latest book "Tubes & Circuits"
It uses the earlier 40V heater PL509/519 top cap sweep tube rather than the newer production octal based JJ EL509.
Other than that I followed Bruce's circuit and layout to the letter.
Steve
Old 25th October 2012, 09:21 PM   #4389
carolus is online now carolus  Belgium
It is my take on the new Transcendent "Son of Beast" ...
Steve
Hi Steve,
Congrats with your new "son" OTL ...
Nice unit.
Did you a "point-to-point" wiring (or pcb)?
Did you a test/measure about power output (before clipping) and stability Dc-output?
My experiences with OTL T12(concept Trancendent): the PL519 is a good tube (even second hand after test).
(This is not a product placement)
Old 25th October 2012, 10:20 PM   #4390
I did a point to point job.
I have not measured the power output, but Bruce quotes 15WPC.
The amp is rock stable with the DC offset staying at zero once set.
Once the initial setup and consequent settling in period has expired (about three days)
The whole thing is set and forget.
Photo GalleryHide this!Advertise here!
