Photo Gallery
Photo Gallery
Old 4th September 2012, 01:50 PM   #4311
mhouston is offline mhouston  Australia
mhouston's Avatar
Originally Posted by soundbrigade View Post
I have made a stereoamp with two tubes, one is a 12AT7 and the second a 5998A. Dual powertubes are great, or at least can make interesting projects. I am fiddling with one 832 but have cast glances on some obsolete Russian 6R3S from my Priboj. Each tetrod in the tube is rated 20W.
I usually see you on diyaudioprojects. Do you have an image of the tubes?
Old 4th September 2012, 02:42 PM   #4312
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
OK, here's the 5998A:
Not finished but this will be my 5998A PSE:
The Russian dual powertetrode looks like this. Socket is the GU-50 type socket:
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 4th September 2012, 03:20 PM   #4313
artosalo is offline artosalo  Finland
artosalo's Avatar
Is there sufficient gain with one 12AT7 combined with low mu 5998A?
Your Priboi pcb looks more than typical with burned resistors and circuit board .
One douple tetrode that I like is GMI-6. It gives 20 W with very low distortion in pp-mode.
Old 4th September 2012, 04:20 PM   #4314
5998A is very much like 6AS7G, but has higher gain, but the 12AT7 handles the tube most perfectly.
I had the Priboi rebuilt but will some day rebuild it again and throw in, either a bunch of GU-50, or 6P36S (EL500) or maybe just some 6L6.
/Magnus
Old 4th September 2012, 07:59 PM   #4315
artosalo's Avatar
If you change the output tubes to GU-50, then take the supply voltage for the phase splitter/amplifier tube (6N6P) from 420 V line. With original supply voltage the swing of the phase splitter is far too low for GU-50.
One of my friend just modified one a couple weeks ago.
Old 5th September 2012, 10:45 AM   #4316
I used this schematic for the modification:
http://www.pastisch.se/tubes/images/Priboj_sch.jpg.
Have to re-wire the power tranny.
/Magnus
Old 7th September 2012, 10:41 PM   #4317
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
finally got this off the breadboard and into a box..after nearly 5 years...
Vitalstates- Amplifiers
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 7th September 2012, 11:46 PM   #4318
mhouston's Avatar
vitalstates: really very nice. To go to the effort of painting the Hammonds is a fine touch and looks like an excellent heavy paint job on chassis etc.
Old 8th September 2012, 05:33 AM   #4319
richwalters is offline richwalters
richwalters's Avatar
........and underneath looks ?
Old 8th September 2012, 05:57 AM   #4320
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
S&M Rubber Duckie looks like he's in love.
jeff
Photo GalleryHide this!Advertise here!
