Photo Gallery - Page 416 - diyAudio
Old 26th June 2012, 08:07 AM   #4151
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by Sander'Z View Post
6SL7/4x6SN7/6X5 phono stage/preamlifier.
Damn! That's nice!! I really like the lap joints in the woodwork. The component outline with the tube types indicated is a nice retro touch as well. Nice work. Thanks for sharing.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 26th June 2012, 02:27 PM   #4152
boywonder's Avatar
Sander: Looks great. Where are you getting the custom stickers/decals?
Old 26th June 2012, 02:36 PM   #4153
Sander'Z's Avatar
tomchr, boywonder, thank you!
Labels I do myself. I draw in Corel Draw and then print out on a laser printer (Samsung ML-1215) on plain paper. Varnished and glued with double-sided adhesive tape.
Old 26th June 2012, 08:19 PM   #4154
Professor's Avatar
Sander'z Perfect work! What type of varnish you use?
http://mymegahobby.jimdo.com/
Old 26th June 2012, 08:48 PM   #4155
zman01 is offline zman01  Bangladesh
Very nice Sander'Z!
Old 27th June 2012, 03:26 AM   #4156
Very nice work!
Tom
Old 27th June 2012, 06:18 AM   #4157
Default Jadis 30 clones .. Audio8 boards
I built a couple of these . Used Tango (ISO) transformers I picked up in Tokyo recently
The boars come from audio8 they could be smaller .. I used the provided (huge ) power supply boards in one but did one on a tag board on the other.
I think Iwill provide some balanced inputs for them as I am using long lines.
Old 27th June 2012, 08:53 AM   #4158
Sander'Z's Avatar
MOTIP Dupli-Color.
Old 27th June 2012, 09:57 AM   #4159
the timber is Tasmanian oak and the varnish is a spray gloss estapol.. lots of sanding. the corners are pine moulding
Old 27th June 2012, 11:27 AM   #4160
roline is offline roline  United States
roline's Avatar
Default KEG-EAR AUDIO AMP
6L6-KT88 based amp, UL-Triode selectable. 60 watt Hammond 4.3k output iron. PCB is toner transfer method etched in a sink, brass eyelets used for all wire and underboard caps. worked with low cost 6P3S Russian 6L6 to KT88 tubes. 6550=C= were the best to my ears in triode mode. LED bias monitors on front to indicate a bias shift or bad tube. Oak chassis with 10 coats of tung oil.
SO many tubes, SO little time!!!
Copyright 1999-2017 diyAudio
