Photo Gallery
Photo Gallery
Old 12th March 2012, 04:21 PM   #3971
M Gregg is offline M Gregg  England
Originally Posted by jane View Post
6C33 monoblocs.
6SL7 input, 6V6 driver and 6C33 power tube.
Hammond mains transformers, Sowter plate choke and Edcor OPT.
Schematic:
JanE
Nice build,
It would be interesting to see a picture of how you sink 21.8 Watt in the chassis (Cathode)..Is it single resistor?
M. Gregg
Old 12th March 2012, 05:16 PM   #3972
jane is offline jane  Norway
jane's Avatar
Rk is 2 x 330R/17W resistors.
The temperature on the surface of the chassis (near to the cathode resistors) is 56 C after playing for 2-3 hours.
Jan.
Life is hard - Then you die.
Old 12th March 2012, 05:21 PM   #3973
chrisb is offline chrisb
Jan.
tidy work - any reason not to use Dale or equivalent aluminum/finned resistors bolted directly to chassis in such an application?
Old 12th March 2012, 05:29 PM   #3974
LesFaul is offline LesFaul  Croatia
Nice work jane! PSU schematic available?
Old 12th March 2012, 05:45 PM   #3975
jane's Avatar
No particular reason, 330R/17W was what I had..
Jan.
Old 12th March 2012, 06:30 PM   #3976
buzzforb is offline buzzforb  United States
buzzforb's Avatar
The bass sounds tight and well defined. I have chosen a 1k2 OPT that brings the output impedance down without feedback. My speakers start to sound muddy if the Zo from the amps are too high, but that's not the case here.
Output power is 12W+, noise level is ~190ÁV (mainly 50Hz) measured on the binding posts.
I have just listen to the amps for a few hours so I cant tell much more for the moment..
THanks. I eagerly await further listening results
...Shape the sound , Man!
Old 13th March 2012, 03:49 PM   #3977
jim is offline jim  Belgium
My new SE EL34 amp.
Old 13th March 2012, 03:52 PM   #3978
hidnplayr is offline hidnplayr  Belgium
hidnplayr's Avatar
Originally Posted by jim View Post
My new SE EL34 amp.
What preamp tube did you use?
Also, do you have a good source for those nice old bakkelite knobs?
Real tubes have top-caps
Old 13th March 2012, 03:59 PM   #3979
Preamp tube is a 6021 (12AT7WA) but will be replaced with an ECC801S.
That knob is from an old power supply. I used some polish to clean it.
Old 13th March 2012, 05:36 PM   #3980
dady is offline dady  Europe
dady's Avatar
Send a message via MSN to dady Photo Gallery
Question What for is the link for Fairchild?
Please if is possible to say what is the objective for the list for Fairchild?
Best Regards
Esteban Bikić
Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
