| diyAudio Sponsor | ||
| Thread Tools | Search this Thread |
#3891 |
Esteban Bikic |
#3892 | |
Guess you don't have a You tube clip? What OP Tx's have you used? (Original) Regards M. Gregg
What is the sound of one hand clapping? |
#3893 | |
OPTs are made by Mr. Krklec and they are the highest quality and sound OPTs for very reasonable money. Last edited by bbakota2000; 3rd February 2012 at 01:26 PM. |
#3894 |
Thanks for the link to Mladen Krklec... i had lost that one.
#3895 |
KT88 Single Ended with Parallel 6N7 input valves...Sound is sweet and detailed.B+ 390vdc for output and 330v for input tubes.
#3896 |
Nice amp!
I really like the kt88 sound. What mode are you running it? Triode-UL -pentode?
Tim |
#3897 |
Running the KT88's in triode mode atm...got no UL taps on the output transformers
saving my pennies for a pair of Edcor or Hammond.
#3898 |
Hi, I wanted to present my design SE amp with tubes - the 6SL7 input / SRPP /. The EL34 output tubes operate in the triode system. The amplifier is no loop NFB. The amplifier works with speakers, OB - 15" EV SP15A / SP15A woofer, mid Beyma 8MI100 and horn Extra Cone / Greetings Dinkers
#3899 |
Hello
Good power, great power tubes Regards, Alexander |
#3900 |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| jacobthellamer, vconsumer |
| Page generated in 0.11164 seconds (68.81% PHP - 31.19% MySQL) with 11 queries |
