Photo Gallery
Photo Gallery
Old 1st February 2012, 12:00 PM   #3881
Peter Georgescu is offline Peter Georgescu  Germany
Originally Posted by Cassiel View Post
(a floating paraphase stolen from a Leben amp) It's all about the circuit really
Sounds interesting thanks for your short description. Did you draw the circuit?
So you obviously use solid state rectification and RC filter. Why not There seem to be two RCA jacks....one input and one thru (for connecting a sub or something)?
Best,
Peter
Old 1st February 2012, 01:45 PM   #3882
Cassiel is offline Cassiel  Libya
Err, I didn't draw the circuit. This paraphase thing is personal taste anyway, concertina phase splitters are alright too. I always recommend people to experiment, to find out what they like and to make things as simple as possible. I dislike ostentation. I dislike audio trends.
You don't need a choke -it's a Push Pull amp. Besides, for whatever reason it sounds better with a resistor. I like tube rectifiers but I needed all the juice I could get.
It's a mono amp. I listen in mono in my basement (that's right, MONO) and I also play guitar, so one input is often used with a guitar preamp.
Old 1st February 2012, 01:56 PM   #3883
M Gregg is offline M Gregg  England
Some argue with mono you get a perfect centre image..
Then again whats the point of stereo in a background setting when you move around the room and get left then the other side you get right..mono is much better in this situation..
And yes the resistor with no choke is a different sound...thats why I use capacitor bypass on the choke in my SE....Then they don't sound yuk!
M. Gregg
Old 1st February 2012, 02:07 PM   #3884
I was talking about the 6AS7 as SE output tube. Yuk, yuk. I have nothing personal against good SE amps. Hey, I even have some.
Old 1st February 2012, 05:03 PM   #3885
azazello is offline azazello  Bulgaria
azazello's Avatar
Cassiel,
HeadWize - Project: A Single-Ended OTL Amplifier for Dynamic Headphones by Aren van Waarde
Old 1st February 2012, 07:07 PM   #3886
trondareo is offline trondareo  Norway
trondareo's Avatar
I just finished a Sweet little single ended russian.
6S45P triodes driven at 175V/40mA
5U4C rectifier.
Nice golden glow 100mA dials
Musical Power Supplies Transformer 190.2i
Edcor GXSE 10W-6ohm-5K
Oiled beech frame and 1,5mm alu top.
Im having my fist listening session now, and Im Happy!
Im doing stuff at http://taooftubes.wordpress.com/
Old 2nd February 2012, 01:49 AM   #3887
tomchr is offline tomchr  Canada
tomchr's Avatar
That's nice work! I like the beech. Nice, bright wood.
Where did you find the mA meters?
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 2nd February 2012, 03:07 AM   #3888
Thanks for the link Azazello. I knew that circuit, one thing I find odd is that Mr. Van Gaarde doesn't have it on his webpage, instead there's a SS circuit.
Aren’s Attic
I also know that P. Millet designed a commercial headphone amp with the 6AS7. His circuit dissipates too much heat for my liking.
Trondareo - I believe white tube amps may become fashionable and I like the idea. It looks good.
Old 2nd February 2012, 07:45 AM   #3889
trondareo's Avatar
Thanks Tom!
The mA meters are from jims_audio (Hong Kong) on Ebay.
Current meter 100mA tube biasing warm back light ! | eBay
Old 3rd February 2012, 09:54 AM   #3890
bbakota2000 is offline bbakota2000  Croatia
Audio Note Japan Neiro clone. PSE 2A3, 6072A, 5687.
Absolutely the best tube amp
Photo GalleryHide this!Advertise here!
