#3811 |
Int.Amp. Single-Ended Parralell 807 (RCA.) V12 Pure-Class,A 80 watt/ch.
sanit |
#3812 |
#3813 |
Mains TX for this and previous Aikido were both custom wound by Shinrock and they are totally silent. 0.7mV hum both channels. |
#3814 |
Hi everyone!
My first Tube Amp working at low Voltage of 24Vcc. The output power is about 2W @ 8 ohm. I used one PL504 and one 12FQ7 (ECC82/83 are also OK) ![]()
#3815 |
Interesting use of the tubes,
When is the stereo version being made? ![]() Where did you get the circuit diagram? Regards M. Gregg
What is the sound of one hand clapping? |
#3816 |
The circuit diagram was found on the web, but I modified it quite a lot
![]() I will post it soon. |
#3817 |
#3818 |
A 6BM8 Stereo SE amp I built.
Switchable triode/pentode mode. Audio level indicator tubes. Viewable in action at: Tube Amp REV 2 Part 5 - Finished.wmv - YouTube I enjoy listening to is almost as much as I enjoied building it! |
#3819 |
Hey pilovis, I see you care for audiophile grade parts.
Also, feeding that big tube with only 24V is going to make him angry - good for hard rock.
Hello |
#3820 |
