Photo Gallery
Photo Gallery
Old 4th December 2011, 04:29 AM   #3761
GloBug is offline GloBug  Canada
Banned
Here ya go, I've been using it for a few days now.
Still needs a wood base when I get to the hardware store next.
Old 4th December 2011, 04:35 AM   #3762
pageboy is offline pageboy  United States
I will have to build something that looks like this. I did buy a pair of light fixtures last summer at a garage sale of which the bases look darn near identical to this. I planned to use them in a room in the house here, but... Let's see, house project vs. tube amp. I wonder what will happen.
Could you post the schematic of these?
Old 4th December 2011, 04:37 AM   #3763
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
Originally Posted by GloBug View Post
UFO!
RH84 stuffed into a light fixture.
Changes - 6V6, 5Y3
Telefunken 5k OPt's
Sounds out of this world, no pun intended.
Neat. That needs a clear bell jar cover like on an old mantle clock.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 4th December 2011, 04:42 AM   #3764
Banned
It's basically a RH84 - http://www.tubeaudio.8m.com/RH84/rh84.html
The changes are 6V6 instead of EL84. (I'm using a 330ohm cathode resistor instead of the 270ohm in the schematic. My power transformer has a little higher voltage then called for.)
12AT7 also has been upped to 270ohm from 250.
Also the power supply in mine is a 5Y3 with a 22u-1.5H-80u pi filter. The schematic is using a 5U4 with a bigger choke and more capacitance. I just did what seemed "safe" with the Duncan's PSUD. I wanted to add more capacitance, but was getting warnings using the 5Y3. Sounds fine though.
I get a very small amount of hum, either from the OPT's being close to the PT, or because I'm not using much filtering. It is very tolerable though, I can only hear it with very sensitive speakers and nothing playing.
Yes I do need to find some glass for it!
Old 5th December 2011, 04:23 PM   #3765
Professor is offline Professor  Russian Federation
Professor's Avatar
Default Hi! My first step in tube sound =)
This is 6N6P SRPP headphone amp. I made delay of anode voltage feed and anode voltage stabilizer.
Thanks to Wawebourn for help! =)
http://mymegahobby.jimdo.com/
Old 5th December 2011, 04:30 PM   #3766
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Photo Gallery
smooothie
Old 5th December 2011, 07:35 PM   #3767
mhouston is offline mhouston  Australia
mhouston's Avatar
Professor: too nice.
Old 5th December 2011, 08:04 PM   #3768
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
Photo Gallery
Worked quite a while on the chassis and the modular way it is built up. Had some people at my place and they all liked the way I 'screwed' this amp together (hardly any solder). I am preparing some better pictures and explanation for a separate thread.
The amp is based on this design by Michael Koster.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 5th December 2011, 08:13 PM   #3769
mostly thinkerer
Photo Gallery
And another amp, also based on a design by Michael Koster. I did, however, implement a splitting trafo (LL1540) at the input so it is push pull. Gyrators load the ECC88 triodes and provide biasing from a low source for the 6W6GT triode-wired output tubes.
The green blocks are slighlty modified PCB terminal blocks: they make excellent connecting points as the 'cage' construction does not damage the components: a major problem with my prior experiments: the Borg Collective.
Old 5th December 2011, 08:16 PM   #3770
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
über cool!!!
If you can see the speaker cone move...it's not hifi.
Photo GalleryHide this!Advertise here!
