#3471 |
Is there a USA equiv. for that?
#3472 |
6BQ5 and 6DJ8
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#3473 |
Those tubes I know, thanks for that.
#3474 |
my output tubes are 6p43p,input is ecc83.
ı tried my amp with el84,6p43p,6p14p, but now ı use 6p43p.
Hüseyin Güngör |
#3475 |
KT88/6550 PP. outside:
#3476 |
Mayky: looks very serious. How many watts can you squeeze out of the amp?
#3477 |
My finished 300B. Tubes are TJ Full Music 300BSE premium limited edition, Avat Australian made power tranni, 50 year treasure 6SN7, Audio Note Silver and Mylar inter-stage caps, Mundorf M Tube poly filter caps, Hammond 30W OPTs, Hammond 10H choke , seperate dual secondary tranni for the 300B heaters (rectified and regulated), Golden Draggon 5U4G and silver wire in the audio path. Parts cost AU$3.5K
Made for a fellow member of the Melbourne Audio Club.
| "VoXDeuX" - Inexpensive two-way speakers | "VoXItBassO"- Stereo 12" sub-woofers |Oatley K272C - headphone amp in a tin can Last edited by mhouston; 30th May 2011 at 11:01 AM. |
#3478 | |
How many watts ? Hmm, already this is a empty box. not ready yet. But I hope 40 W or more with UL connection, in AB class. Last edited by mayky; 30th May 2011 at 11:16 AM. |
#3479 | |
Wow, that set up looks very cool indeed. I bet the new owner is pleased.
Show us what ya got at Homebuilt Hi-fi |
#3480 | |
Nice !!!
Where'd you get the chassis from ? I'm getting back into the DIY audio after a bit of a hiatus, and am thinking that wood is good ![]() Quote:
