Old 1st April 2011, 12:09 AM   #3331
mhouston's Avatar
Originally Posted by Evenharmonics View Post
It's refreshing to see metal enclosure for tube gears after barrage of woody chassis.
Still waiting to see someone come up with wooden input and speaker terminals.
Have to agree. I think the wood is a nice relief though from plain Hamond chassis. Nothing more boring. A mix somethimes works well too.
Old 1st April 2011, 03:00 PM   #3332
Cassiel is offline Cassiel  Libya
Cassiel's Avatar
That spaceship was designed to travel at speed of light, your amp is going to be still most of the time, no fancy aerodynamics needed. Oh and in case you move it around the room I predict turtle pace, that thing looks heavy; only advantage is that you can hold it by the horns or antennas or bulging eyes or whatever that is.
after thousands of wooden boxes
Yeah, pretty tired of those myself.
Old 1st April 2011, 05:57 PM   #3333
trondareo's Avatar
My daughter named it the moose!
I am quite happy that the amp provokes different opinions.
The function of form is to communicate meaning, create experiences and ideas. Good design obviously functions, that is its reason for being. Beyond function products should be good to use, pleasing and interesting. All these factors are contextual, and in the eyes of the beholder.
I have seen hundreds of wood chassis amplifiers, Some are exquisitely well detailed and proportioned. I plan to make one for myself (6C33C) to go with my Empire Scientific turntable, and can only hope to come close.
I am quite happy with the expression of weight, that "stalker" mentions. I have been exploring ways to give the spheres more volume to match the body better. I will have separate B+, signal and heater cables that I hope will achieve better balance of the totality. It is stunt design so nothing is planned yet.
I´m doing stuff at http://taooftubes.blogspot.com/
Old 2nd April 2011, 11:37 PM   #3334
Dylan is offline Dylan  United States
Dylan's Avatar
I'd like to show off my very first scratch-built audio component.
This is my take on the Van Waarde 6DJ8+6AS7 OTL headphone amplifier project. It uses my own non-regulated solid-state supply with a thermal relay to delay full B+ for a minute or so. A small lamp seen in front of the relay turns off when the amp is fully preheated -- sort of like the lamp on an oven.
Performance wise, I surprised myself with this. Despite having everything on one chassis, the background is silent, and the amp sounds beautiful. In fact, now I can hear every flaw in the rest of my equipment! I made an effort to bring all grounds to one point, so I'm sure that helped it quite a bit.
Overall, I'm very proud of my first amplifier.
To those curious, the big chunk of equipment behind it is my 120V:0-240V variac that I found in quite poor shape at a junk store, and lovingly restored.
I got lucky and found the 6AS7G and four "Bugle Boy" 6DJ8/ECC88 for $5 each at another local shop.
Old 2nd April 2011, 11:49 PM   #3335
mhouston's Avatar
Share the schematic?
Old 3rd April 2011, 12:09 AM   #3336
Dylan's Avatar
Sure, here it is as I've built it. I am by no means an expert on this stuff yet, so if anything looks silly that would be why.
The amplifier itself is pretty much unchanged, other than some slight value substitutions based on what was available. The B+ supply is also similar, other than using a bridge rectifier I had on hand and a delay on the primary side.
I chose not to regulate the heater supply (and I don't even have the big filter cap on it right now, either) but it sounds fine to me; at least better than anything I've heard so far.
Of course a bit of B+ appears at the start due to current through the preheat lamp, but not all the way until the relay closes.
Old 3rd April 2011, 05:23 AM   #3337
mhouston's Avatar
Two things I note here is: 6AS7(s) have extremely low plate impedance to start with and it is a cathode follower. Both of these factors mean low output impedance. I like.
Have you varied the orginal schematic?
Old 3rd April 2011, 05:38 AM   #3338
I've been considering building a version for my 'phones, but with possibly ccs loading for both tubes, pentodes or mosfets possibly. How transparent would yo say the amp is?
Old 3rd April 2011, 08:52 AM   #3339
looks nice!
all DC coupled too!
might give it a try myself!
finished a 6EM7 headphone amp and had quite a bit of trouble keeping it quiet.
in the end it was the fillement of the rectifier tube vibrating with 50Hz.
do you need the fan?
Old 4th April 2011, 02:24 AM   #3340
AndreiR is offline AndreiR  United States
Default my new amp
Hi all!
Here is my new thing that the friend of mine made for me -- based on Fisher x-100-c with lots of upgrades. Sweet! Click the image to open in full size.
Copyright ©1999-2013 diyAudio
