Photo Gallery
Thanks Junm,
The submini is the 6N16BV.
I'll have the schematic later (have yet to draw it) but it is very simple, a CCDA: a plate follower + cathode follower on the output with some sensible NFB use.
That's what exactly the tube i was thinking...I have done 6N16b Aikido before and still have enough supply of them, and now i must try that ccda from Tubecad if that's exactly it is...
12J5GT tube buffer
cathode follower, B+ at 320v, op at 150v, 6mA....
very quiet amp, no hum, no hiss...:cool:
Hello all,
I've been doing some experiments with the subminiature tubes.
They are indeed wonderful devices for audio.
Highly reccomended!
This is my latest linestage, the VTR LS3i:
[ ]s
Ricardo
Perfect work, the point to point suspended over the contrast that the button give to the view in the fiberglass button reveals a delicate finish, the socket coming from rimlock (I guess) without metal edge is a clever decision. 6N16 nice tube election nice curve.;)
Many thanks all you guys for the kind words.
The 6N16 is a 8 wire arrangement and not very friendly for a casual experiment because one has to solder them all around in a perfect circular pattern.
So I wondered about using an 8 pin CI socket but.. too small, fragile and I would have to get a PCB done for that, one way or another...
The solution came to my mind like this:
The rest was pretty easy to implement.
[ ]s
Ricardo
Here we go again....after 9 months solitary confinement another 500W behemoth, same weight (55kg) and power appears from the lab. Same identical performance to the other two I made earlier.
One was sold to a music studio.
Eagle eyed members may spot the photo of a Neve Console in the top rh corner. There lies one of my audio secrets as sometime ago I worked in the famed Rupert Neve empire as a tester and designer....the discipline to achieve quality sound changes one, and the same approach reflected in my tube amps for both MI and HiFi.
richy
DIYTube Budgie SE
Here's a unique build of the DIYtube Budgie SE (Single Ended). This one features Elna Silmic II electrolytics, Koa Speers resistors, a Noble potentiometer, Cardas wiring, and Russian silver mica caps. Everything is mounted to a 0.1" thick copper plate and is sitting on a copper leafed wood frame.
You'll find some more details here: DIY Audio Electronics from Zynsonix.com: DIYTube Budgie SE 3W Single Ended Amplifier
I made this PP 6L6 amp many years ago. It is based on an article in Glass Audio by Joseph Norwood Still. I made many improvements. I parted her this year... I need to pay my bills. :(
It looks a lot like a Zenlabs. I like the RF style goround plane.
