Next my experiment - just finished....SE E130L-Micron & 6Н8С & СГ4П with "monster" sound - about 10 Watt per channel. Cool tube! OT about 100 W- core 12 sq. cm, gray iron plate 0.3 mm.
https://picasaweb.google.com/109570777566485968551/Amplifiers#6008120183370077250
E130L and СГ4 in the dark: https://picasaweb.google.com/109570777566485968551/Amplifiers#6008481071039449874
I forgot to change the knob....
Wow....I had a look at your Picasa gallery.
Amazing loudspeakers.
I'm a fan of woodworking, more than electronik. I'll pick some good ideas from it if allowed.
Loudspekers made out of plywood layers e.g.
Ok ...no problem.Thanks for the info.
Thanks mhouston 🙂 next project EL300PPDHT2009: extremely nice. You should be proud.
My Hi-Fi Headphone amp project
Hi, after a long time I finished my project Hi-Fi headphone amplifier. These are photos of the first production series for my friends and buddies. Perhaps you will like them.
PS: Excuse my bad English
More pictures here:
Gallery
more graphs here
Best regards
Marek
More pictures here:
Gallery
more graphs here
Best regards
Marek
I'm curious as to what voltage/RAA you will use 🙂next project EL300PP
Nice I used the same power supply simulator change the value of the cap esr from 2 ohm to the spec sheet it changes the results some but not much. Regards![]()
PSU for EL300PP
I used polies in my 300B also. I used Mundorf M-Tube caps. Not cheap but when you want something very special you must start with a very special PS.Integrated 300B amp I made many years ago. All polypropylene power supply.
I have Mundorfs too in power supply.
- Tubes / Valves
- Photo Gallery
