Photo Gallery
Photo Gallery
Old 28th September 2010, 07:18 PM   #3021
M Gregg is offline M Gregg  England
Originally Posted by Sander'Z View Post
Inside view.
Interesting layout.
Thank's for the photo!
Old 28th September 2010, 07:21 PM   #3022
Sander'Z is offline Sander'Z  Russian Federation
Sander'Z's Avatar
Originally Posted by M Gregg View Post
Interesting layout.
Real point-to-point...
Old 28th September 2010, 07:43 PM   #3023
djn is offline djn  United States
djn's Avatar
Geez Head, you find the coolest tubes.
Originally Posted by head1962 View Post
Hi guys,
need help! found a bunch of these beautiful HUGE Telefunken RS329g transmitting triodes.
Anyone got a data sheet? These MUST be used in a big AMP.
thanks for any help!!! (the foto on the right is not right ;-))
Old 28th September 2010, 07:46 PM   #3024
djn's Avatar
Utopia, can you tell us more about your GM70? I will have mine done in a couple weeks. I am running a two stage at 850v B+ driving the GM70 with a 12HL7 with a CCS on the HL7. Here is a pix so far. Also, what are you doing for the filliment PS?
Originally Posted by utopia View Post
Hi
This is one of my amps:
Gm70
6sn7=>6h30=>300b=>gm70
Old 29th September 2010, 04:55 PM   #3025
utopia is offline utopia  Poland
More on the Polish forum
Wzmacniacz na GM70 - Audiostereo.pl
Schematic
Old 2nd October 2010, 10:40 PM   #3026
torrence is offline torrence  United States
torrence's Avatar
I still need to change out the plate leads for something better looking, but here is a quad 832 parallel push-pull amp running in UL mode. The driver is a 6SL7 direct coupled to a 6SN7 concertina phase splitter.
Last edited by torrence; 2nd October 2010 at 10:45 PM. Reason: Screwed up images the first time
Old 5th October 2010, 10:06 PM   #3027
Mr_Zenith is offline Mr_Zenith  United States
Mr_Zenith's Avatar
Photo Gallery
I've seen so many of other folk's projects on this forum, so I figured I'd get in on the action, too. Pictured here is yet another RH84. Since I happened to have a pair of Hammond 125ESE's lying about, I breadboarded the circuit just to see what all the fuss was about - and it sounded incredible! Good enough, in fact, for me to spend some serious coin on the pair of nice James 6112HS OPT's for the final build.
The PT is a Hammond 270HX (275-0-275, 200 mA); the filter choke is a Hammond 193H (5H @200 mA). The end bells were stripped of the old finish and painted with a satin black heat-resistant paint. I wound up using a 5V4 rectifier instead of a 5U4 to shave 1A off the filament current and provide a "soft start". The meters monitor both power supply voltage and current, and were purchased from Weber Kits (yes, I know the meters aren't registering in the photo - the amp had been switched on just before snapping the shutter).
I constructed the chassis frame of Brazilian Cherry (Hymenaea courbaril). The corner columns were turned from curly maple and regular (American) cherry. All woodwork was given a coat of sanding sealer, sanded smooth, and finished with three coats of spray lacquer. The aluminum deck was lightly sanded and given several coats of hammer-finish paint. The light spots on the paintwork aren't chipped paint, BTW; they're just reflections from the lights I used.
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 5th October 2010, 10:15 PM   #3028
mhouston is offline mhouston  Australia
mhouston's Avatar
Excellent build.
Old 11th October 2010, 12:37 PM   #3029
Cassiel is offline Cassiel  Libya
I'll give the amp a 9. Towel gets a 6.
Old 14th October 2010, 09:07 PM   #3030
tomchr is offline tomchr  Canada
tomchr's Avatar
Love the camera, tripod reflection in the getter flash of the rectifier tube...
Very nice build though.
Photo GalleryHide this!Advertise here!
