| diyAudio Sponsor | ||
| Thread Tools | Search this Thread |
#21 |
Splendid stuff! I'm particularly impressed by the coil winding machine.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#22 |
Some of my ideas on how to finish my amp. So far I build a prototype with junkparts, but am planning on how to build it and lay-out the parts. The top and rear will be from black chromed steel plate, with a satin finish. The sides possibly from a darker type of wood, wild cherry maybe.
Please advice on improvements. Top:
"Be carefull who's advice you buy, but be patient with those who supply it." From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen) |
#23 |
Front and rear:
#24 |
Won't you want more than one input? Do the components you're going to connect between the valves mean that they need to be spaced that far apart? You won't be able to see the volume setting when seated. A steel top plate might couple the leakage field from the mains transformer into the signal valves. They're all fairly minor points.
#25 | |
diyAudio Senior Member
If possible I'd advise to mount the RCAs on the front, this way they and the attached interconnects: a) don't disturb the nice look of the pre. b) put much less strain on the cables. Other than that it looks very good. Cheers,
Frank |
#26 | ||
Thanx for other advice. Quote:
#27 |
You want something conductive, so that means a metal. You don't want it to be magnetic, so that excludes most steels (some stainless steel is non-magnetic, but it's tough to work). Aluminium is the most popular choice, followed by copper, and silver for the crazies.
#28 |
I've used 3 mm thick circuit board for that, copperfoil side facing upwards, grounded and finished with sprayed on varnish. Looks good, sounds good and is cheap... If it needs to support somme heavy stuff such as xformers you may need to reinforce it from underneath to prevent sagging. Cheers,
Frank |
#29 | |
#30 | |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| ronaldw441 |
| Page generated in 0.11538 seconds (65.76% PHP - 34.24% MySQL) with 11 queries |
