Photo Gallery
Photo Gallery
Old 23rd April 2010, 04:25 AM   #2841
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Photo Gallery
Originally Posted by astouffer View Post
Dummy load in an old SCSI drive case.
Grand Pris is yours!
I prepared it today for tomorrow's experiment called "Wavebourn Surprise". It will be some very crazy hybrid design. I need it to be able to dissipate about kilowatt on 16 Ohm.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 23rd April 2010, 05:12 AM   #2842
head1962 is offline head1962  Switzerland
it's on!
Old 24th April 2010, 06:38 AM   #2843
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
yesterday i got a pair of column shape 6P3P.i compare them with the old calabash shape 6P3P.i like the column.
from my eye view,they are same core,same age made by shuguang factory of china 1971.
Old 24th April 2010, 07:34 AM   #2844
that will get hot, hot, hot....
Old 24th April 2010, 11:07 AM   #2845
what are you going to burn off in that?
are you building a tube amp with 1kW output power?
I built one with 1kW supply power, that's already frightning...
good luck!
Old 25th April 2010, 12:00 PM   #2846
Default SE OTL 6EM7 headphone amp
just finished my first head phone amp.
Cathode follower. DC coupled.
Sounds marvelous!!
Took me a long, long, long time to get rid of all the humm.
Now it's perfectly clean though.
Had to rectify and ground (thanks Jörg) the heaters of the 6EM7's, something I'd never needed to do before.
And put some transformer metal above and below the mains transformer.
The sides are going to be a bit different, 25mm black Acryl and the thransformer cover still needs to be done.
if anyone's interested in buying one... or the diagrams...
let me know
Old 25th April 2010, 05:58 PM   #2847
Steve Cresswell is offline Steve Cresswell  United Kingdom
Steve Cresswell's Avatar
Here's an amp I have just completed.
It is a single-ended amp based on the British 13E1 beam tetrode.
The 13E1 is triode strapped and is driven by a 6EM7 twin dissimilar triode combination.
The front end gain is high as I was considering incorporating a degree of feedback into the design, but the amp sounds so good without it that I am wondering if it is worth bothering with feedback now.
Output transformers are from the UK Majestic Transformer Company and are gapped for 200mA. Impedance is 1K25 into a 4ohm load.
Excellent output transformers they are too
Old 25th April 2010, 06:12 PM   #2848
adamus is offline adamus  United Kingdom
looks fantastic, i have been following the build on audio talk. - nice little forum.
Old 25th April 2010, 11:42 PM   #2849
gabrielbecheanu is offline gabrielbecheanu  Romania
gabrielbecheanu's Avatar
Send a message via MSN to gabrielbecheanu Send a message via Yahoo to gabrielbecheanu
Hi
I have just completed my amp too.
A 20W SE Class A amplifier with 6C33C. I love it.
Old 26th April 2010, 01:30 AM   #2850
digi01's Avatar
very nice 6c33c building.even better than brand!
Photo GalleryHide this!Advertise here!
