Beautiful work, I enjoyed your article of this amplifier in audioXpress magazine. I wonder what is the input sensitivity of this circuit? If I add a input selector and a volume control, can this so be used as integrated amp?An externally hosted image should be here but it was not working when we last tested it.
2x6F12P SE. My new spud...
Just another toy, a bit of a Frankenstein cirquit
and here is the "video"...
DIY 2x6F12P SE Valve Amplifier - YouTube
Very well done .Just another toy, a bit of a Frankenstein cirquit
Very nice. And I like the France Gall soundtrack.
(song: France Gall - Laisse tomber les filles 1964 HD (Tele Melody) - YouTube)
(and April March sings in English: Chick Habit - YouTube)
This thing sits on my desk between my computer audio line out, and a pair of vintage Minimus 7 speakers.
There are lots of one tube SE amps. Then, one day, someone asked about building a one tube PP amp. This is what I came up with. You see two tubes in the pic, because this is the stereo version. Tubes are 6M11 Compactrons, pentode/dual triode. Output power is in the 300mW range (Class A), which is enough when I'm sitting only 3 feet away.
Passive components, excluding power supply, are on a PCB. Hmm, I need to make the OTP's look prettier.
Original idea
Very well done. Mala k
Is it good operating point for transformers speaker you used?Just another toy, a bit of a Frankenstein cirquit
According to this
One formula for output impedance of a tube:
Zout = Va/(Pa/Va), where
Va = Plate (anode) voltage
Pa = Maximum plate (anode) dissipation
from here:
AX84.com - The Cooperative Tube Guitar Amp Project
i think it is a good estimation (consider also the parallel configuration)
Any other suggestions/thoughts are very wellcome.
from here:
Im the last one to declare i am aware on electronics, but if we apply the numbers on the previous equation {Zout = Va/(Pa/Va) } with Va=201.2 and Pa=5W the outcome is around 8k.
Also for the triode section we get something like 11.5k.
Now as they act in parallel i think 7k and 5k respectivly seems ok and even a bit "over dummed".
But as i already said i may be wrong.
It's great!
The unusual finish.
___________________________________________________________________
It's part of my earlier craft...
6f5m+6s4s se amp
Very nice build! Can you please post schematics of this amp
And one more ...
- Tubes / Valves
- Photo Gallery
