diyAudio Sponsor
Old 9th November 2009, 09:09 PM   #2641
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I like the Dynaco look and setup. So you found the transformers yesterday. And made pcb's and got it fired up in one day!!!! I'm jealous.
Old 9th November 2009, 10:14 PM   #2642
richwalters's Avatar
Well well; alot of similarity, ECL82 7W per channel. Drop-through o/p trannies; home-made mains tranny different orientation. Not a touch of hum..Fixed bias operation.
squad= balanced input trannies: front end 12GN7 as triode; split load p/s ECC88. I like the sound but 8K primary is a touch soft on the upper register, neverless an easy amp to build with a remarkable performance and sounds astonishingly loud and clean when put against a 20 Watter.
richy
Old 11th November 2009, 07:38 AM   #2643
Default My new pre line with phono stage
Hi all my new pre, the design is mr Allen W[ATTACH][ATTACH][ATTACH]100_1138.JPG[/ATTACH][/ATTACH][/ATTACH]rite.
Old 11th November 2009, 12:29 PM   #2644
[ATTACH][ATTACH]100_1142.JPG[/ATTACH][/ATTACH] and this
Old 12th November 2009, 03:02 PM   #2645
mckvak is offline mckvak  Czech Republic
takiskatsikas : Nice work
Old 12th November 2009, 07:04 PM   #2646
It's a beast,
Grommes becomes Frazier Power amp turned mega bass crazy;
4 output tubes 6GT5A's
rapevan now where did those guys go?
Old 23rd November 2009, 07:04 PM   #2647
Tetrode is offline Tetrode  United States
Default My "Brook" sytle 6B4G PP intergrated
Converts stereo into mono
Old 23rd November 2009, 08:29 PM   #2648
Default My Black Velvet OTL headfones amplifier
6H13C & Rare CV200/600 & PCC88 Siemens /yellow pins/
OTL for headphones 200 and more ohms. Loftin-white, only 1 cap ELNA CE between output stage and headphones.
Picasa Π£Π΅Π± Албуми - Azazello - amplifiers
Old 25th November 2009, 08:03 AM   #2649
Tubie Noobie
Default 12B4 Linestage
First Tube Construction
12b4 linestage built based on threads here. CLCLC Filter with 2x OD3 for 300V B+. Resistive loaded plate with a LM317CCS on the cathode keeping the tube biased at 20mA with 150V plate voltage. Have not played with LED bias yet. Built P2P but embarrased to show it as wiring is UGLY. No hum so I guess it is good enough for now.
Chasis made of Cherry and Maple of local origin.
The gas reference tubes add a very nice light to the amp.
Living Life Doing the Waltz in 4/4 meter.
Old 26th November 2009, 12:25 AM   #2650
Molloy is offline Molloy  Europe
Account Disabled
#2649
The hand that rocks the cradle.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
runing, fordanto
Page generated in 0.13898 seconds (60.92% PHP - 39.08% MySQL) with 11 queries
