| diyAudio Sponsor | ||
| Thread Tools | Search this Thread |
#2631 | |
what diagram did you use? gerrit |
#2632 |
Hands down the coolest build I've seen around here in a long time ... if not ever. I wish I'd thought of doing that.
http://www.ecpaudio.com |
#2633 |
Hello head1962,
the basic schematics for the pearl white 211, was from a Japanese magazine. I guess MJ. The gain in the driver stage is too high, this was adjusted. Also the power supply is changed, higher voltage for 211. Use original 6SN7 tubes - the remake tubes sounds not so nice. Here the original schematic: |
#2634 | |
It is definitely the easiest way to build a box. Doesn't get messy or nothing. And you need to know someone with a laser, if not you prabably go bankrupt :-(( No heat build up either which should be good for something.. here's 2 other amps, more orthodox, say Gerrit |
#2635 | |
I saw a lot of other nice builds too - like it when the builder aims at a small smize.
/Magnus
#2636 |
#2638 | |
Banned
#2639 |
#2640 |
I have been busy with other stuff for tha last year, yesterday i stumbled upon two 8k PP xformers in a box, i digged out two pairs of matched 6P14P and two 6N1P and fired up the soldering iron, sounds beautiful although still a prototype.
www.joddla.net/audio/ |
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| vgeorge |
| Page generated in 0.11859 seconds (63.28% PHP - 36.72% MySQL) with 11 queries |
