Photo Gallery
Photo Gallery
Old 25th July 2008, 07:32 PM   #2151
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Just acquired
It's a Philips Stereo record player amp.
2x ECC83 and 2x EL95
Volume (with loudness), bass, treble and balance
My summer project
(sorry - rubbish photo)
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 25th July 2008, 09:48 PM   #2152
Rodango is offline Rodango  United States
Rodango's Avatar
Send a message via AIM to Rodango Send a message via Yahoo to Rodango
Default Re: Re: Rodango Model DB-1 Bass Guitar Head
Originally posted by FastEddy
... Wondering if those high temp wire wound resistors cause any questions/problems? Is this usual or do many 'philes replace 'em?
No, they work great and are the cathode bias resistors...
Old 26th July 2008, 02:00 PM   #2153
jane is offline jane  Norway
jane's Avatar
Small SE "office amplifier" based on EF184 and 6L6C/KT66 (or any other tubes that fit into the socket) Distributed feedback: 3-4dB local shunt feedback and 8-9dB gNFB.
Jan E Veiset
Life is hard - Then you die.
Old 26th July 2008, 09:50 PM   #2154
igormak is offline igormak  Russian Federation
igormak's Avatar
Hi Jane,
At last we see SE ultraline pentode paradise and in very good execution. Congrats!
Jane, how it sounds?
Old 27th July 2008, 09:19 AM   #2155
JAMESBOS is offline JAMESBOS  England
Hi Jane,
Looks like a nice simple SE design, a sort of universal SE Amp, which can use several different valves of the same or very similar pin outs. I myself have built a universal SE Amp which can use about 14 different valves of the same general pin out!Although not quite as neat and simple as your design. I also used meters to set the different bias. I would like to build this design to compare it with mine. What is the B+Voltage. Do you use fixed bias? If so what is the original bias voltage? You must forgive my ignorance as I have no knowledge of the maths of building or designing Amps. I just follow the schematics and hope it works!!
If it doesn't I don't have the means of putting it right I just move on to the next schematic and keep my fingers crossed that I don't make any silly mistakes! My universal SE Amp is still working after about 6 years now so I must have done something right! It uses EL 38's as the Output valves and 6J5GT's for the input and a GZ37 as rectifier, at about 400Volts. Best regards Anthony.
HENRY
Old 27th July 2008, 10:59 AM   #2156
jane's Avatar
Here is the power supply. The mains transformer is a Hammond 372JX. B+ is ~360Vdc. Bias is adjustable between ~25 and ~45V so most of the power tubes with 7AC/8EP pin layout will do the trick (EL34, 6550, KT66, 5881, KT90, etc).
Jan E Veiset
Old 27th July 2008, 01:53 PM   #2157
kmtang is offline kmtang  Canada
kmtang's Avatar
Default Super Power Plate for my Preamp
Here is my latest Tube Regulated Power Supply for my new Preamp.
It includes Lundahl LL1650 power trans, 2x LL1623AM amorphous chokes as double choke filtering, 47+47uF Blackgate capacitor, and Tube Regulator (6EM7, 6U8A and 5651) based on HP400's schematic.
My wife said this monster sounds very nice but too expensive for me to keep.
http://photoshare.shaw.ca/messages/v...5065/page/1/15
Old 27th July 2008, 08:55 PM   #2158
speakerfritz is offline speakerfritz  United States
kmtang
you have a schematic for that power supply?
Old 6th August 2008, 06:53 AM   #2159
mayham is offline mayham  Netherlands
Hi there,
Here's my latest creation. Still working on it though. Some issues with PSU transformer overheating and hum induced on the anode chokes. But that's almost fixed.....
For more pictures on the build check my website. (-:
Next project is going to be a very tiny (REALY tiny) Push-pull amplifier using 6am4 and E90CC tubes. ((-:
Try to find a sane man; If you do, send him to me and I'll cure him.
Old 6th August 2008, 07:29 AM   #2160
Oh yeah, btw. This is what it is:
'27 preamp using 5z3 for rectification and two huge 25h chokes. Included are two L1667 anode chokes. Five inputs, two outputs.
B+ running at 200v. Sounds like a charm (-:
Photo GalleryHide this!Advertise here!
